- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Resources
- Task Capture Integration
- Automation Store
- Email Notifications
- Video Tutorials
- Additional Resources
Customizing the Detailed Assessment
OUT OF SUPPORT
Automation Hub User Guide
Last updated Nov 11, 2024
Note:
- A maximum of 50 questions can be added.
- Each question can have a maximum of 20 answers.
- The customized questions are displayed in the Additional Information section of each Detailed Assessment.
- The algorithm score is not affected by these questions.
Add your first customized question to the Detailed Assessment by following the below steps:
Click Customize. The Assessment Customization page is displayed.
As this is your first question, click Create Question.
Note: Once a question is created, it cannot be removed still, it can be hidden from the assessment by using the Disable option. -
The question configuration window is displayed. Complete it with the question information.
Note:- All questions marked as Enabled are displayed in the Idea Assessment form.
- When turned on, the Required option makes the question as mandatory for completing the Idea Assessment form.
- Click Save.
The newly created question is displayed in the Assessment Customization page.
To add more questions or edit saved ones follow the below steps:
- Click Edit.
- Check for the question you want to edit and apply the updates or click Add Question to add a new question.
- Click Save.
To view the video version of this process please access Video Tutorials section > Admin Console > Customize the Detailed Assessment.
