- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
To find out more about the core concepts used in an Automation Suite deployment, see Glossary.
The default installation experience includes a choice of two product selections:
- Complete (All products) – Install the complete list of products available in Automation Suite. For details, see Automation Suite products.
Select products – Allows you to select and install only the products you are interested in. Note, however, that the installer takes the cross-product dependencies into consideration. That means that if a product requires the installation of another product, you must install both of them. For details, see Cross-product dependencies.
Note:You can enable additional products later in the same deployment at any point in time, after the initial installation, without having to reinstall. For details, see Managing products.
We recommend validating the hardware requirements based on expected usage and ensuring the deployment has enough capacity before adding additional products. For details, see Capacity planning.
You can deploy Automation Suite in either single-node evaluation or multi-node HA-ready production mode. While most of the prerequisites for the two profiles are identical, multi-node HA-ready production mode requires additional resources.
Once the deployment starts, you cannot switch or upgrade from one deployment profile to another. Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
Deployment profiles at a glance
Deployment profile |
Prerequisites |
Installation |
Single-node profile: supported only for evaluation and demo scenarios, not for production deployments |
One Linux machine with supported RHEL version and ipcalc tool installed. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibily matrix.
Note:
DNS | ||
TLS 1.2+ | ||
IPv4 Important: IPv6 is not supported.
Trusted TLS, token-signing and SQL connection encryption certificates | ||
Proxy server (optional) | ||
Kerberos authentication (optional) | ||
External objectstore (optional) | ||
External Docker registry (optional) | ||
Multi-node HA-ready profile: the only configuration supported for production deployments |
Minimum 3 Linux machines with supported RHEL version and ipcalc tool installed. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibily matrix.
Note:
DNS | ||
TLS 1.2+ | ||
IPv4 Important:
IPv6 is not supported. | ||
Load balancer | ||
rke2-selinux package is not installed automatically. If you experience SELinux-related issues, you must install the SELinux policy package
manually. For details, refer to the How to... Section.
- You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, see Root privileges requirement.
Cilium requires CAP_SYS_ADMIN permissions to function correctly. Make sure these permissions are granted.
- Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
- UiPath does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
To avoid potential installation issues, make sure that all nodes used in the deployment are set to the same time zone.
Before you begin, consider the following:
- Automation Suite supports Federal Information Processing Standard 140-2 (FIPS 140-2). You can perform a clean installation
of Automation Suite on a FIPS 140-2-enabled host. You can also enable FIPS 140-2 on a machine where you previously performed
an Automation Suite installation. For details, see Security and compliance.
Note:
Insights is currently not supported on FIPS-enabled hosts. Make sure to disable Insights when installing Automation Suite on a FIPS-enabled host.
- The minimum hardware requirements do not protect the deployment from node failures.
- The multi-node HA-ready production profile is resilient to only one node failure. This means that you can lose only one server node. This restriction does not apply to agent nodes. You can lose as many agent nodes and still continue to use the cluster without downtime as long as enough overall cluster capacity is available.
- You can increase the server node tolerance to failure by following the instructions in Advanced installation experience.
The following sections list out the hardware requirements for both the Complete product selection and individual products.
Complete product selection: hardware requirements
The following sections describe the hard requirements for the Complete product selection.
General requirements
Hardware for all products |
Single-node minimum requirement |
Multi-node minimum requirements |
Processor per cluster |
32 (v-)CPU/cores |
96 (v-)CPU/cores |
Minimum processor per node |
N/A |
8 (v-)CPU/cores |
RAM |
64 GB |
192 GB |
Minimum RAM per node |
N/A |
16 GB |
Cluster binaries and state disk for each node1 |
256 GB SSD Min IOPS: 1100 |
Data disk2 |
512 GB SSD Min IOPS: 1100 |
etcd disk for server node |
16 GB SSD Min IOPS: 240 |
UiPath bundle disk (For offline installation only, on one of the server nodes) |
Objectstore3 |
1 The cluster disks capacity may need to be increased based on your AI Center ML skills and training storage requirements.
2 The data disk is used as a block store.
3 This refers to the in-cluster objectstore and is not applicable if you use external objectstore.
If you install Automation Suite in single-node evaluation mode, and you do not have a machine with 32 (v-)CPU/cores and 64 GB of RAM, you can bring machines with a minimum of 8 (v-)CPU/cores and 16 GB of RAM. For more details, see Capacity calculator.
If you choose this option, follow the multi-node installation and configuration instructions.
It is recommended to bring external objectstore whenever possible. This helps in scaling the objectstore independently of the cluster, and brings additional stability. We support the following objectstore options:
- Azure storage account
- AWS S3 storage bucket
- S3 compatible storage bucket
Additional Task Mining requirements
Task Mining requires an additional agent node that must meet the following requirements:
Hardware |
Minimum requirement |
Processor |
20 (v-)CPU/cores |
RAM |
60 GB |
Cluster binaries and state disk |
Data disk |
N/A |
Additional Automation Suite Robots requirements
In multi-node HA-ready production environments, Automation Suite Robots require an additional agent node. In single-node evaluation environments, an additional Automation Suite Robots node is optional.
The hardware requirements for the Automation Suite Robots node depend on the way you plan to use your resources. In addition to the additional agent node requirements, you also need a minimum of 10 GB to enable package caching.
The following sections describe the factors that impact the amount of hardware the Automation Suite Robots node requires.
Robot size
Size |
CPU |
Memory |
Storage |
Small |
0.5 |
1 GB |
1 GB |
Standard |
1 |
2 GB |
2 GB |
Medium |
2 |
4 GB |
4 GB |
Large |
6 |
10 GB |
10 GB |
Agent node size
The resources of the Automation Suite Robots agent node have an impact on the number of jobs that can be run concurrently. The reason is that the number of CPU cores and the amount of RAM capacity are divided by the CPU/memory requirements of the job.
For example, a node with 16 CPUs and 32 GB of RAM would be able to run any of the following:
- 32 Small jobs
- 16 Standard jobs
- 8 Medium jobs
- 2 Large jobs
Job sizes can be mixed, so at any given moment, the same node could run a combination of jobs, such as the following:
- 10 Small jobs (consuming 5 CPUs and 10 GB of memory)
- 4 Standard jobs (consuming 4 CPUs and 8 GB of memory)
- 3 Medium jobs (consuming 6 CPUs and 12 GB of memory)
Kubernetes resource consumption
Given that the node is part of a Kubernetes cluster, the Kubernetes agent present on the server (kubelet) consumes a small amount of resources. Based on our measurements, the kubelet consumes the following resources:
- 0.6 CPU
- 0.4 GB RAM
A node similar to the one previously described would actually have approximately 15.4 CPUs and 31.6 GB of RAM.
Automatic machine size selection
All your cross-platform processes have the Automation Suite Robots option set to Automatic by default. This setting selects the appropriate machine size for running the process using serverless robots.
When automatically choosing the size, the criteria listed in the below table are evaluated in order. As soon as one criterion is satisfied, the corresponding machine size is chosen and the remaining criteria are not evaluated.
Order |
Criterion |
Machine size |
1 |
Remote debugging job |
Medium |
2 |
Process depends on UI Automation OR Process depends on the UiPath Document Understanding activities |
Standard |
3 |
Other unattended process |
Small |
Additional Document Understanding recommendations
For increased performance, you can install Document Understanding on an additional agent node with GPU support. Note, however, that Document Understanding is fully functional without the GPU node. Actually, Document Understanding uses CPU VMs for all its extraction and classification tasks, while for OCR we strongly recommend the usage of a GPU VM. Here you can find more information about the CPU/GPU usage within the Document Understanding framework.
If you want to use an additional node with GPU support, you must meet the following requirements:
Hardware |
Processor |
8 (v-)CPU/cores |
RAM |
52 GB |
Data disk |
N/A |
GPU RAM |
11 GB |
For more details, see AI Center considerations.
Individual products: hardware requirements
For details on the hardware requirements your must meet to install individual products or various product combinations in Automation Suite, use the Automation Suite Install Sizing Calculator.
Before starting the Automation Suite installation, you must ensure you meet the following requirements:
- you have a RHEL subscription;
- you enabled the BaseOS and AppStream repositories;
- you installed the required RPM packages.
The following table lists the required RPM packages:
RPM package |
Description |
Required on nodes for installation. |
Required on nodes for the execution of the readiness check. |
Required on the orchestration node for the execution of the
uipathctl.sh functionality requiring Ansible.
Required for offline installations only. |
RHEL 8.4 and later have the required RPM packages in the BaseOS and AppStream repositories by default.
Manual installations
If you perform a manual clean installation of Automation Suite, you must ensure you meet the RPM package requirements. In this case, you are responsible for installing the required RPM packages.
If you upgrade from a previous Automation Suite version, you have already installed the RPM packages.
For details on the tools you can use to install and validate RPM packages, see the following:
Cloud templates
If you install Automation Suite using our Azure, AWS, or GCP templates, no action is needed from your side. The templates provision the full infrastructure, including the RPM packages.
The installation requires an external SQL server as a prerequisite. Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
Individual product support varies.
For each product you plan to deploy, you must:
- check the supported version of SQL Server as required by the product;
- apply the SQL Server configuration prerequisites, including SQL Server User permission, as required by the product.
For more information on product-specific SQL Server requirements, see SQL Server configuration for single-node evaluation profile and SQL Server configuration for multi-node HA-ready production profile.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
- 8 (v-)CPU
- 32 GB RAM
- 256 GB SSD
These minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements that are needed for reliable operation.
To enable a backup, an external NFS server is required. Automation Suite supports NFSv4 on Linux.
The general minimum hardware requirements for NFS Server are as follows:
CPU |
RAM |
Disk |
4 (v-)CPU |
8 GB |
2 TiB SSD (1100 IOPS) |
The following table lists the RHEL versions supported by each version of Automation Suite:
Automation Suite version |
Supported RHEL versions |
| 2023.4.13 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5 |
2023.4.12 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5 |
2023.4.11 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5 |
| 2023.4.10 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4 |
2023.4.9 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4 |
| 2023.4.8 | 8.6, 8.8, 8.9, 8.10, 9.2 |
| 2023.4.7 | 8.6, 8.8, 8.9 |
| 2023.4.6 | 8.6, 8.8, 8.9 |
| 2023.4.5 | 8.6, 8.8, 8.9 |
| 2023.4.4 | 8.6, 8.8 |
| 2023.4.3 | 8.6, 8.8 |
| 2023.4.2 | 8.6, 8.8 |
| 2023.4.1 |
8.6 |
| 2023.4.0 |
8.6 |
kernel-4.18.0-372.91.1.el8_6 and kernel-4.18.0-477.10.1.el8_8 are affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite
nodes uses these kernel versions either pre- or post-installation.
- Terminology
- Product selection
- Choose your deployment profile
- Deployment profiles at a glance
- Hardware requirements
- Complete product selection: hardware requirements
- Individual products: hardware requirements
- RPM package requirements
- Manual installations
- Cloud templates
- Microsoft SQL Server general requirements
- NFS Server general requirements
- RHEL compatibily matrix
