Last updated Dec 4, 2025
Automation Suite not working after OS upgrade
After an OS upgrade, Ceph OSD pods can sometimes get stuck in CrashLoopBackOff state. This issue causes Automation Suite not to be accessible.
Solution
  1. Check the state of the pods by running the following command:
    kubectl -n rook-ceph get podskubectl -n rook-ceph get pods
  2. If any of the pods in previous output are in CrashLoopBackOff, recover them by running the following command:
    OSD_PODS=$(kubectl -n rook-ceph get deployment -l app=rook-ceph-rgw --no-headers | awk '{print $1}')
    kubectl -n rook-ceph rollout restart deploy $OSD_PODSOSD_PODS=$(kubectl -n rook-ceph get deployment -l app=rook-ceph-rgw --no-headers | awk '{print $1}')
  3. Wait for approximately 5 minutes for the pods to be in running state again, and check their status by running the following command:
  • Description
  • Solution
