- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Last updated Dec 4, 2025
The prerequisite check for
selinux iscsid module might fail in the following scenarios:
selinux iscsid module fails with the following error:
Validating Selinux iscsid module... STARTED
[WARN] [2023-06-08T11:02:36+0000]: Selinux module uipath-iscsid-dac is not installed
[INFO] [2023-06-08T11:02:36+0000]: Installing uipath-iscsid-dac selinux module
libsemanage.semanage_get_lock: Could not get direct transaction lock at /var/lib/selinux/targeted/semanage.trans.LOCK. (Resource temporarily unavailable).
semodule: Failed on /opt/UiPathAutomationSuite/UiPath_Installer/Prerequisite_Checks/hardware-validation/uipath-iscsid-dac.pp!
>>> [FAILED] Validating selinux policy for iscsid failed as module uipath-iscsid-dac is not loaded
* Installation of iscsid selinux module failed.
* Please follow our troubleshooting guide for more details.
Validating Selinux iscsid module... DONE
>>> [FAILED] One or more installation readiness checks are failed
---Validating Selinux iscsid module... STARTED
---Solution
To fix this issue, rerun the
validateUiPathASReadiness.sh script.
selinux iscsid module fails due to permission issues.
Solution
To fix this issue, apply the policy manually by running the following command:
cd Prerequisite_Checks/hardware-validation
checkmodule -M -m -o uipath-iscsid-dac.mod uipath-iscsid-dac.te
semodule_package -o uipath-iscsid-dac.pp -m uipath-iscsid-dac.mod
semodule -X 300 -i uipath-iscsid-dac.ppcd Prerequisite_Checks/hardware-validation
