- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
install-uipath.sh manual installer allows you to customize the installation experience without running the interactive installer (installUiPathAS.sh).
While the manual installer is suitable for advanced scenario, the deployment templates and the interactive installer are still the recommended options.
install-uipath.sh installer is available in as-installer.zip. For download instructions, see Downloading installation packages.
--input -i <string>
.json file.
input.json refers to the cluster_config.json that defines the parameters, settings, and preferences applied to the UiPath® services deployed via Automation Suite. You
need to update this file to change the defaults and use any advanced configuration for your cluster. For details, refer to
Manual: Advanced installation experience.
--output -o <string>
.json file.
output.json refers to the output file of the manual installer.
--install-kubernetes -k
Install the Kubernetes cluster.
--join-node -j <server|agent>
-k. Determines the type of node to be joined to an existing cluster. Allowed values: <server|agent>.
--install-fabric -f
Install the fabric components.
--install-services -s
Install the UiPath services.
--install-all -a
–install-all will be implied.
--install-type <online|offline>
online. You cannot set it to online together with –offline-bundle.
--offline-bundle <string>
Specify the path to the offline bundle. Indicates that the installation method is tarball.
--offline-tmp-folder <string>
--offline-bundle or --optional-offline-bundle. Specify the parent directory for the temporary offline installation folder. Defaults to /tmp.
--optional-offline-bundle <string>
Specify the path to the optional offline bundle.
--pre-reqs -p
Check prerequisites. When using this flag, no other flags can be passed.
--install-offline-prereqs
Used with the tarball installation method, performs the installation of all prerequisites.
--skip-packages-install
Skips the installation of prerequisites during the online installation method. By default, prerequisites are installed.
--upgrade -u
Upgrade an existing Automation Suite cluster.
--kubeconfig <string>
/etc/rancher/rke2/rke2.yaml.
--backup -b
Back up the cluster.
--restore -r
Restore the cluster.
--restore-volume
Restore volume.
--disable-backup
Disable the backup.
-d
Run in debug mode.
-h
Display help.
--accept-license-agreement
Mandatory flag to accept the license agreement.
-c
Install Cilium CNI (Container Network Interface) to replace the default Canal. Only used during upgrade. You cannot use it with any installation flag.
--skip-pre-reqs
Skip prerequisite checks during installation. Note that you cannot skip RPM package validation.
--one-time-manual-backup
Trigger manual backup and disable it after completion.
-m|--machines <comma separated machine's IP>
Specify the targeted machines for installation. Provide comma-separated IP addresses or hostnames of all the machines.
--compare-config
input.json file with the current cluster configuration.
--skip-compare-config
Skip compare the current config with the cluster state.
- Install the Kubernetes cluster components on the VM where it is executed, using the online installation method.
install-uipath.sh -i ./input.json -o ./output.json -k --accept-license-agreementinstall-uipath.sh -i ./input.json -o ./output.json -k --accept-license-agreement - Install the Kubernetes components on the VM where it is executed, and join it to the existing cluster as a server, using the
install-uipath.sh -i ./input.json -o ./output.json -k -j server --accept-license-agreementinstall-uipath.sh -i ./input.json -o ./output.json -k -j server --accept-license-agreement - Perform the complete installation on the current VM, using the online installation method. Includes the Kubernetes cluster
components, the Fabric, and the Uipath services.
install-uipath.sh -i ./input.json -o ./output.json -a --accept-license-agreementinstall-uipath.sh -i ./input.json -o ./output.json -a --accept-license-agreement - Perform the complete installation on the current VM, using the online installation method. This time, skip the prerequisites
installation.
install-uipath.sh -i ./input.json -o ./output.json -a --skip-packages-install --accept-license-agreementinstall-uipath.sh -i ./input.json -o ./output.json -a --skip-packages-install --accept-license-agreement - Perform the Kubernetes cluster installation, using the tarball installation method. Also, join the node to the existing cluster
and install all the offline prerequisites.
install-uipath.sh -i ./input.json -o ./output.json -k -j agent --offline-bundle "/tmp/as-infra.tar.gz" --accept-license-agreement --install-offline-prereqsinstall-uipath.sh -i ./input.json -o ./output.json -k -j agent --offline-bundle "/tmp/as-infra.tar.gz" --accept-license-agreement --install-offline-prereqs - Install the fabric and services components using the offline installation method, without a temporary folder provided.
install-uipath.sh -i ./input.json -o ./output.json -f -s --offline-bundle "/tmp/as-infra.tar.gz" --accept-license-agreementinstall-uipath.sh -i ./input.json -o ./output.json -f -s --offline-bundle "/tmp/as-infra.tar.gz" --accept-license-agreement - Execute the installer for an offline installation, but without loading the artifacts.
install-uipath.sh -i ./input.json -o ./output.json --install-type offline -s --accept-license-agreementinstall-uipath.sh -i ./input.json -o ./output.json --install-type offline -s --accept-license-agreement - Execute the installer skipping the prerequisites check
install-uipath.sh -i ./input.json -o ./output.json -k --accept-license-agreement --skip-pre-reqsinstall-uipath.sh -i ./input.json -o ./output.json -k --accept-license-agreement --skip-pre-reqs
- Required parameters
--input -i <string>--output -o <string>- Optional parameters
--install-kubernetes -k--join-node -j <server|agent>--install-fabric -f--install-services -s--install-all -a--install-type <online|offline>--offline-bundle <string>--offline-tmp-folder <string>--optional-offline-bundle <string>--pre-reqs -p--install-offline-prereqs--skip-packages-install--upgrade -u--kubeconfig <string>--backup -b--restore -r--restore-volume--disable-backup-d-h--accept-license-agreement-c--skip-pre-reqs--one-time-manual-backup-m|--machines <comma separated machine's IP>--compare-config--skip-compare-config- Examples
