- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Security and compliance
linkEnabling FIPS 140-2
linkFederal Information Processing Standards 140-2 (FIPS 140-2) is a security standard that validates the effectiveness of cryptographic modules.
You can enable FIPS 140-2 on the machines on which you install Automation Suite in the following scenarios:
- Enable FIPS 140-2 before performing a clean installation of Automation Suite 2023.4 or later. For details, see. Scenario 1: new installations
- Enable FIPS 140-2 after performing an Automation Suite installation on a machine with FIPS-140-2 disabled. For details, see Scenario 2: existing installations.
To enable FIPS 140-2 on the machines where you plan to perform a fresh installation of Automation Suite, take the following steps:
- Before starting the Automation Suite installation, enable FIPS 140-2 on your machines.
- Perform the Automation Suite installation by following the installation instructions in this guide.
- If you install AI Center on a FIPS 140-2-enabled machine and also use Microsoft SQL Server, some additional configuration is required. For details, see:
- Make sure Insights is disabled as it is not supported on FIPS 140-2.
- Make sure your certificates are FIPS 140-2-compatible.Note:
By default, Automation Suite 2023.4 and later generates self-signed FIPS 140-2-compatible certificates whose expiry date depends on the type of Automation Suite installation you choose.
You are strongly recommended to replace these self-signed certificates with CA-issues certificates at installation time. To use Automation Suite on FIPS 140-2-enabled machines, the newly provided certificates must be FIPS 140-2-compatible. For a list of eligible ciphers supported by RHEL, see RHEL documentation.
- To update the token-signing certificates, run:
sudo ./configureUiPathAS.sh identity token-cert update --cert-file-path /path/to/cert --cert-key-file-path /path/to/certkey
sudo ./configureUiPathAS.sh identity token-cert update --cert-file-path /path/to/cert --cert-key-file-path /path/to/certkey - To update the TLS certificates, run:
./configureUiPathAS.sh additional-ca-certs update --ca-cert-file /path/to/ca/certs
For more on certificates, see Managing the certificates.
You can install Automation Suite on machines with FIPS 140-2 disabled, and then enable the security standard on the same machines. This is also possible when you upgrade to a new Automation Suite version.
To enable FIPS 140-2 on the machines where you already performed an Automation Suite installation, take the following steps:
- Perform a regular Automation Suite installation or upgrade operation on machines with FIPS 140-2 disabled.
- Enable FIPS 140-2 by running the following command on all your machines:
fips-mode-setup --enable
fips-mode-setup --enable - Make sure your certificates are FIPS 140-2-compatible.Note:
To use Automation Suite on FIPS 140-2-enabled machines, you must replace your certificates with new FIPS 140-2-compatible certificates signed by a CA. For a list of eligible ciphers supported by RHEL, see RHEL documentation.
- Make sure your product selection is in line with the FIPS-140-2 requirements:
- If you previously enabled Insights, you must disable it as it is not supported on FIPS 140-2. For details on how to disable products post-installation, see Managing products.
- Reboot your machines and check if you successfully enabled FIPS 140-2 by running the following command:
fips-mode-setup --check
fips-mode-setup --check - Rerun the
install-uipath.sh
service installer:-
In an online environment, run:
./install-uipath.sh -i cluster_config.json -o output.json -s --accept-license-agreement – Online -- online
./install-uipath.sh -i cluster_config.json -o output.json -s --accept-license-agreement – Online -- online -
In an offline environment, run:
./install-uipath.sh -i ./cluster_config.json -o ./output.json -s --offline-bundle /uipath/tmp/sf.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
