Last updated Dec 23, 2025
Step 3: Post-deployment steps
Important: You can currently use the GCP deployment template only with Automation Suite 2024.10. We therefore recommend referring to the Automation Suite 2024.10 documentation.
Updating certificates
The installation process generates self-signed certificates on your behalf. These certificates are compliant with FIPS 140-2 and will expire in 90 days. You must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
If you installed Automation Suite on a FIPS 140-2-enabled host and want to update the certificates, make sure they arecompatible with FIPS 140-2.
For instructions, see Managing certificates.
Enabling FIPS 140-2
After completing an Automation Suite installation using the GCP deployment template, you can enable FIPS 140-2 on your machines. For instructions, see Security and compliance.
Accessing the deployment outputs
To get the deployment outputs, take the following steps:
  1. Open a terminal.
  2. Go to the directory from which you ran the deployment commands.
  3. Execute the following command:
    terraform outputterraform output
The output should look similar to the following image:
Output definitions
The outputs give you the necessary information for accessing the suite and the cluster.
The following table describes the values:
Key
fqdn
The fully qualified domain name provided for the installation. Make sure you use the same one when configuring the DNS.
For instructions on how to configure the DNS, see:
lb_ip
The load balancer’s IP address used for configuring the DNS.
bastion_ip
The IP address of the bastion VM needed to access the cluster via SSH.
deployment_id
The deployment ID included in the name of all the resources in a deployment.
db_credentials
The URL to the secret containing the credentials for the database.
as_host_credentials
The URL to the secret containing the credentials for the Host organization in the Automation Suite portal.
as_default_credentials
argocd_credentials
The URL to the secret containing the credentials for the ArgoCD console used to manage the installed products.
longhorn_monitoring_url
The URL to Longhorn monitoring tools: https://monitoring.${var.lb_fqdn}
grafana_monitoring_url
The URL to Grafana monitoring tools: https://monitoring.${var.lb_fqdn}/grafana
prometheus_monitoring_url
The URL to Prometheus monitoring tools: https://monitoring.${var.lb_fqdn}/prometheus
alertmanager_monitoring_url
The URL to Alertmanager monitoring tools: https://monitoring.${var.lb_fqdn}/alertmanager
Accessing the Cluster Administration portal
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, see Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
Go to the following URL: https://${CONFIG_CLUSTER_FQDN}/uipath-management.
Note: You do not need any credentials to access the Cluster Administration portal.
Accessing the services
To access the services, you must have a DNS configured. See Configuring the DNS in a single-node evaluation setup or Configuring the DNS in a multi-node HA-ready production setup for details.
Alternatively, you can follow the instructions in Configuring a client machine to access the cluster for testing purposes only.
If using a self-signed certificate, you may get an certificate error as shown in the following image.
Accessing Automation Suite portal
You can access the Automation Suite portal at https://<fqdn>. You can get the credentials via a secret available at:
  • as_host_credentials URL for the Host organization;
  • as_default_credentials URL for the Default organization.
Accessing ArgoCD
You can access the ArgoCD console at https://alm.<fqdn>. You can get the credentials via a secret that can be found at the argocd_credentials URL.
Accessing the monitoring tools
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
  • Username: admin
  • Password: to retrieve the password , run the following command:
    kubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -dkubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -d
To update the default password used for accessing the monitoring tools, take the following steps:
  1. Run the following command by replacing newpassword with your new password:
    password="newpassword"
    password=$(echo -n $password | base64)
    kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword"
  2. Run the following command by replacing <cluster_config.json> with the path to your configuration file:
    /opt/UiPathAutomationSuite/UiPath_Installer/install-uipath.sh -i <cluster_config.json> -f -o output.json --accept-license-agreement/opt/UiPathAutomationSuite/UiPath_Installer/install-uipath.sh -i <cluster_config.json> -f -o output.json --accept-license-agreement
Accessing the cluster
  1. Open a terminal and use SSH to connect to bastion. You can find bastion_ip in the deployment outputs.
    ssh -i <path_to_private_key> <username>@<bastion_ip>ssh -i <path_to_private_key> <username>@<bastion_ip>
  2. From bastion, you can access other nodes via SSH using the following command. The username must be the same as the one used to connect to bastion. You can find the <node_address> in the GCP console, in the column Internal IP.
    ssh -i .ssh/private_key <username>@<node_address>ssh -i .ssh/private_key <username>@<node_address>
You should see the following dashboard showing the state of the cluster:
Editing the number of nodes
Use the GPC console to edit number of nodes (server or agent nodes) as follows:
  1. In the Instance Group tab, search for the MIGs, and select on the one corresponding to the node type you want to modify.
  2. Select Edit.
  3. Modify the Number of instances field according to your needs, and select Save.
Removing the deployment
If you want to remove the deployment, take the following steps:
  1. Open a terminal and go to the folder where you unzipped the templates.
  2. Run the following command:
    terraform destroyterraform destroy
  3. Type Yes when asked for approval.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
