Last updated Dec 4, 2025
Setting up Kerberos authentication with basic MSSQL authentication for Process Mining
Note:
When you are performing a new installation and you want to use Kerberos authentication, it is strongly recommended to configure process app security as single_account. Refer to Configuring process app security for details.
When you want to use Kerberos authentication for login to Automation Suite and use basic MSSQL authentication for Process Mining you need to add the following in the processmining section in the cluster_config.json file.
"kerberos_auth_config": {
      "enabled": false
    },"kerberos_auth_config": {
      "enabled": false
The following code shows an example processmining section with Kerberos authentication with basic MSSQL authentication for Process Mining.
 "processmining": {
    "enabled": true,
      "enabled": false
    "sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:password%[email protected]:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server",
    "warehouse": {
          "sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
          "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:Password%[email protected]:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server"
    }, "processmining": {
    "enabled": true,
      "enabled": false
    "warehouse": {
