Last updated Dec 23, 2025
SQL connection string validation error
You might receive an error relating to the connection strings as follows:
Sqlcmd: Error: Microsoft Driver 17 for SQL Server :
Server—tcp : <connection string>
Login failed for userSqlcmd: Error: Microsoft Driver 17 for SQL Server :
This error appears even though all credentials are correct. The connection string validation failed.
Solution
Make sure the connection string has the following structure:
Server=<Sql server host name>;User Id=<user_name for sql server>;Password=<Password>;Initial Catalog=<database name>;Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;Server=<Sql server host name>;User Id=<user_name for sql server>;Password=<Password>;Initial Catalog=<database name>;Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
Note: User Id is case-sensitive.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
