OUT OF SUPPORT
Last updated Feb 24, 2025
Hardware and software requirements
Terminology
To find out more about the core concepts used in an Automation Suite deployment, see Glossary.
Product Selection
The default installation experience includes a choice of two product selections. If you want to install a different combination of products, make sure to review the Cross-product dependencies page..
Product
Complete
Basic
Orchestrator
available
available
Action Center
available
available
Test Manager
available
available
Insights
available
available
Automation Hub
available
available
Automation Ops
available
available
Apps
available
not available
AI Center
available
not available
Document Understanding
available
not available
Task Mining
available
not available
Note:
You can enable additional products later in the same deployment at any point in time, after the initial installation, without having to reinstall. For details, see Managing products.
We recommend validating the hardware requirements based on expected usage and ensuring the deployment has enough capacity before adding additional products. For details, see Capacity planning.
Choose Your Deployment Profile
Important:
Linux and Kubernetes knowledge is required regardless of the deployment profile you choose. If you encounter issues installing and configuring Automation Suite, contact UiPath Professional Services.
Once the deployment starts, you cannot switch/upgrade from one deployment profile to another.
Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
Deployment Profiles at a Glance
Deployment profile
Prerequisites
Installation
Single-node profile: supported only for evaluation and demo scenarios, not for production deployments
One Linux machine (RHEL 8.6, 8.8) with ipcalc tool installed
  • Additional Linux machine is required when using Task Mining
  • Additional Linux machine with GPU support is recommended when using Document Understanding
Note:
  • We support new minor versions of RHEL within 90 days of their release.
  • We support SELinux with default policies.
  • Microsoft SQL Server (2016, 2017, 2019, 2022 - Standard and Enterprise editions)
  • Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
DNS
IPv4
Important:
IPv6 is not supported.
Trusted TLS, token-signing and SQL connection encryption certificates
Proxy server
(optional)
Kerberos authentication
(optional)
Multi-node HA-ready profile: the only configuration supported for production deployments
Minimum 3 Linux machines (RHEL 8.6, 8.8) with ipcalc tool installed
Note:
DNS
IPv4
Important:
Load balancer
Proxy server
(optional)
(optional)
Important:
  • You need root permission to install and deploy Automation Suite.For more on the specific components that require root access, see Root privileges requirement.
  • Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
  • UiPath does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
Evaluation or Demo Purposes — Single-node Evaluation Profile Hardware Requirements
Important: Federal Information Processing Standard (FIPS) is not compatible with Automation Suite. If FIPs is enabled at any point on the servers running Automation Suite, the cluster will fail. If FIPs is enabled on any cluster server, the installer will encounter issues blocking the installation.
If you opt for the single-node evaluation profile, you must meet the following hard requirements:
Single-node evaluation profile
(supported only for evaluation and demo purposes)
Selection
Complete
Basic
Processor
32 (v-)CPU/cores
16 (v-)CPU/cores
RAM
64 GiB
32 GiB
Cluster binaries and state disk for each node
256 GiB SSD
Min IOPS: 1100
256 GiB SSD
Min IOPS: 1100
Data disk for server node
2 TiB SSD
Min IOPS: 1100
512 GiB SSD Min
IOPS: 1100
etcd disk for server node
16 GiB SSD
Min IOPS: 240
16 GiB SSD Min
IOPS: 240
UiPath bundle disk
(For offline installation only, on one of the server nodes)
512 GiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
Additional agent node for Task Mining (required)
Processor
20 (v-)CPU/cores
N/A
(Task Mining is not present in this selection)
RAM
60 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
Additional agent node with GPU support for Document Understanding
Processor
8 (v-)CPU/cores
N/A
(AI Center is not present in this selection)
RAM
52 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
GPU RAM
11 GiB
Production Deployment — Multi-node HA-ready Production Profile Hardware Requirements
Important:
The minimum hardware requirements do not protect the deployment from node failures.
To understand your storage needs and plan for them accordingly, see Evaluating your storage needs.
The multi-node HA-ready production profile is resilient to only one node failure. This means that you can lose only one server node. This restriction does not apply to agent nodes. You can lose as many agent nodes and still continue to use the cluster without downtime as long as enough overall cluster capacity is available.
If you opt for the multi-node HA-ready production profile, you must meet the following hard requirements:
Multi-node HA-ready production profile
(the only configuration supported for production deployments)
Selection
Complete
Basic
Node count
At least 3 server nodes.
There must be an odd number of server nodes in a cluster to have increased fault tolerance.
There is no limit on the number of agent nodes
Processor
96 (v-)CPU/cores
48 (v-)CPU/cores
Minimum processor per node
16 (v-)CPU/cores
16 (v-)CPU/cores
RAM total
192 GiB
96 GiB
Minimum RAM per node
32 GiB
32 GiB
256 GiB SSD
Min IOPS: 1100
256 GiB SSD
Min IOPS: 1100
Data disk for each server node
2 TiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
etcd disk for each server node
16 GiB SSD
Min IOPS: 240
16 GiB SSD
Min IOPS: 240
UiPath bundle disk
512 GiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
Processor
20 (v-)CPU/cores
N/A
RAM
60 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
Processor
8 (v-)CPU/cores
N/A (AI Center is not present in this selection)
RAM
52 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
GPU RAM
11 GiB
Note: Larger node sizes are more efficient than smaller node sizes because of the fixed baseline resource overhead per node. For example, 3 x 32 cores nodes is more efficient than 6 x 16 cores nodes.
Microsoft SQL Server General Requirements
Note: Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
The installation requires an external SQL server as a prerequisite. Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
Note: Make sure that the SQL server can be accessed from each cluster VM.
Important:
Individual product support varies.
For each product you plan to deploy, you must:
  • check the supported version of SQL Server as required by the product;
  • apply the SQL Server configuration prerequisites, including SQL Server User permission, as required by the product.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
  • 8 (v-)CPU
  • 32 GiB RAM
  • 256 GiB SSD
These minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements that are needed for reliable operation.
Important: For each product you plan to deploy, you must evaluate projected usage and apply the capacity planning guidance as specified by the product. This information is available in the help section of each individual product.
NFS Server General Requirements
To enable a backup, an external NFS server is required. Automation Suite supports NFSv4 on Linux.
Note: Make sure that the NFS server can be accessed from each cluster VM.
The general minimum hardware requirements for NFS Server are as follows:
CPU
RAM
Disk
4 (v-)CPU
16 GiB
10 TiB SSD (1100 IOPS)
