OUT OF SUPPORT
Last updated Feb 24, 2025
Degraded MongoDB or Business Applications After Cluster Restore
Occasionally, after cluster restore/rollback to version 2022.4.x or 2021.10.x, an issue causes MongoDB or business applications (Apps) pods to get stuck in the initial state. This happens because the volume required for attaching the PVC to a pod is missing.
Solution
  1. Verify if the problem is indeed related to MongoDB volume attachment issue:
    # fetch all mongodb pods kubectl -n mongodb get pods #describe pods stuck in init state #kubectl -n mongodb describe pods mongodb-replica-set-<replica index number> kubectl -n mongodb describe pods mongodb-replica-set-0# fetch all mongodb pods kubectl -n mongodb get pods #describe pods stuck in init state #kubectl -n mongodb describe pods mongodb-replica-set-<replica index number> kubectl -n mongodb describe pods mongodb-replica-set-0
    If the issue is related to the MongoDB volume attachment, the following events are displayed:
    Events:
      Type     Reason              Age                   From                     Message
      Warning  FailedAttachVolume  3m9s (x65 over 133m)  attachdetach-controller  AttachVolume.Attach failed for volume "pvc-66897693-e52d-4b89-aac6-ca0cc5ae9e07" : rpc error: code = Aborted desc = volume pvc-66897693-e52d-4b89-aac6-ca0cc5ae9e07 is not ready for workloads
      Warning  FailedMount         103s (x50 over 112m)  kubelet                  (combined from similar events): Unable to attach or mount volumes: unmounted volumes=[logs-volume], unattached volumes=[hooks mongodb-replica-set-keyfile tls-secret data-volume healthstatus tls-ca kube-api-access-45qcl agent-scripts logs-volume automation-config]: timed out waiting for the conditionEvents:
  2. Fix the problematic MongoDB pods by running the following script:
    #!/bin/bash
    set -eu
    FAILED_PVC_LIST=""
    STORAGE_CLASS_SINGLE_REPLICA="longhorn-backup-single-replica"
    STORAGE_CLASS="longhorn-backup"
    LOCAL_RESTORE_PATH="restoredata"
    mkdir -p ${LOCAL_RESTORE_PATH}
    export LOCAL_RESTORE_PATH="${LOCAL_RESTORE_PATH}"
    function delete_pvc_resources(){
      local pv_name=$1
      local volumeattachment_name=$2
      echo "deleting pv & volumes forcefully"
      delete_pv_forcefully "${pv_name}"
      sleep 2
      delete_longhornvolume_forcefully "${pv_name}"
      sleep 2
      if [ -n "${volumeattachment_name}" ]; then
        echo "deleting volumeattachments forcefully"
        delete_volumeattachment_forcefully "${volumeattachment_name}"
        sleep 5
      fi
    function delete_longhornvolume_forcefully() {
      local pv_name=$1
      if ! kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}" >/dev/null 2>&1 ; then
        echo "Volume ${pv_name} not found, skip deletion."
        return
      fi
      kubectl -n longhorn-system delete volumes.longhorn.io "${pv_name}" --grace-period=0 --force &
      local success=0
      local try=0
      local maxtry=10
      while (( try < maxtry )); do
        local result=""
        # update finaluzer field to null
        result=$(kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}" -o=json | jq '.metadata.finalizers = null' | kubectl apply -f -) || true
        echo "${result}"
        result=$(kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}")|| true
        echo "${result}"
        if [[ -z "${result}" ]]; then
          success=1
          break;
        fi
        echo "Waiting to delete volume ${pv_name} ${try}/${maxtry}..."; sleep 10
        try=$(( try + 1 ))
      done
       if [ "${success}" -eq 0 ]; then
        echo "Failed to delete volume ${pv_name}."
      fi
    function delete_pv_forcefully() {
      local pv_name=$1
      kubectl delete pv "${pv_name}" --grace-period=0 --force &
      local success=0
      local try=0
      local maxtry=10
        result=$(kubectl get pv "${pv_name}" -o=json | jq '.metadata.finalizers = null' | kubectl apply -f -) || true
        echo "${result}"
        result=$(kubectl get pv "${pv_name}")|| true
        echo "${result}"
          success=1
          break;
        fi
        echo "Waiting to delete pv ${pv_name} ${try}/${maxtry}..."; sleep 10
        try=$(( try + 1 ))
      done
        echo "Failed to delete pv ${pv_name}."
      fi
    function validate_pv_backup_available(){
      local pv_name=$1
      local validate_pv_backup_available_resp=0
      local backup_resp=""
      local resp_status_code=""
      local resp_message=""
      local try=0
      local maxtry=3
      while (( try != maxtry )) ; do
        backup_resp=$(curl --noproxy "*" "${LONGHORN_URL}/v1/backupvolumes/${pv_name}?") || true
        echo "Backup Response: ${backup_resp}"
        if { [ -n "${backup_resp}" ] && [ "${backup_resp}" != " " ]; }; then
          resp_status_code=$(echo "${backup_resp}"| jq -c ".status")
          resp_message=$(echo "${backup_resp}"| jq -c ".message")
          if [[ -n "${resp_status_code}" && "${resp_status_code}" != " " && "${resp_status_code}" != "null" && (( resp_status_code -gt 200 )) ]] ; then
          else
            resp_message=$(echo "${backup_resp}"| jq -c ".messages.error")
            if { [ -z "${resp_message}" ] || [ "${resp_message}" = "null" ]; }; then
              echo "PVC Backup is available for ${pv_name}"
              # shellcheck disable=SC2034
              validate_pv_backup_available_resp=1
              break;
            fi
          fi
        fi
        try=$((try+1))
        sleep 10
      done
      export IS_BACKUP_AVAILABLE="${validate_pv_backup_available_resp}"
    function store_pvc_resources(){
      local pvc_name=$1
      local namespace=$2
      local pv_name=$3
      local volumeattachment_name=$4
      if [[ -n "${volumeattachment_name}" && "${volumeattachment_name}" != " " ]]; then
        result=$(kubectl get volumeattachments "${volumeattachment_name}" -o json > "${LOCAL_RESTORE_PATH}/${volumeattachment_name}".json) || true
        echo "${result}"
      fi
      kubectl get pv "${pv_name}" -o json > "${LOCAL_RESTORE_PATH}/${pv_name}"-pv.json
      kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}" -o json > "${LOCAL_RESTORE_PATH}/${pv_name}"-volume.json
      kubectl get pvc "${pvc_name}" -n "${namespace}" -o json > "${LOCAL_RESTORE_PATH}/${pvc_name}"-pvc.json
    function wait_pvc_bound() {
      local namespace=$1
      local pvc_name=$2
      try=0
      maxtry=30
        local status=""
        status=$(kubectl -n "${namespace}" get pvc "${pvc_name}" -o json| jq -r ".status | select( has(\"phase\")).phase")
        if [[ "${status}"  == "Bound" ]]; then
          echo "PVC ${pvc_name} Bouned successfully."
          break;
        fi
        echo "waiting for PVC to bound...${try}/${maxtry}"; sleep 30
        try=$((try+1))
      done
    function create_volume() {
      local pv_name=$1
      local backup_path=$2
      local response
      create_volume_status="succeed"
      echo "Creating Volume with PV: ${pv_name} and BackupPath: ${backup_path}"
      local accessmode
      local replicacount
      accessmode=$(< "${LOCAL_RESTORE_PATH}/${pv_name}-volume.json" jq -r ".spec.accessMode")
      replicacount=$(< "${LOCAL_RESTORE_PATH}/${pv_name}-volume.json" jq -r ".spec.numberOfReplicas")
      # create volume from backup pv
      response=$(curl --noproxy "*" "${LONGHORN_URL}/v1/volumes" -H 'Accept: application/json' -H 'Content-Type: application/json;charset=UTF-8' --data-raw "{\"name\":\"${pv_name}\", \"accessMode\":\"${accessmode}\", \"fromBackup\": \"${backup_path}\", \"numberOfReplicas\": ${replicacount}}")
      sleep 5
      if [[ -n "${response}" && "${response}" != "null" && "${response}" != " " && -n $(echo "${response}"|jq -r ".id") ]]; then
      # wait for volume to be detached , max wait 4hr
        local try=0
        local maxtry=480
        local success=0
        while (( try < maxtry ));do
          status=$(kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}"  -o json |jq -r ".status.state") || true
          echo "volume ${pv_name} status: ${status}"
          if [[ "${status}" == "detached" ]]; then
            # update label
            kubectl -n longhorn-system label volumes.longhorn.io/"${pv_name}" recurring-job-group.longhorn.io/uipath-backup=enabled
            success=1
            echo "Volume ready to use"
            break
          fi
          echo "waiting for volume to be ready to use${try}/${maxtry}..."; sleep 30
          restore_status_url="${LONGHORN_URL}/v1/volumes/${pv_name}?action=snapshotList"
          try=$(( try + 1 ))
        done
          create_volume_status="failed"
          echo "${pv_name} Volume is not ready to use with status ${status}"
        fi
      else
        kubectl create -f "${LOCAL_RESTORE_PATH}/${pv_name}"-volume.json || true
        echo "${pv_name} Volume creation failed ${response} "
      fi
      echo "${create_volume_status}"
    function restore_with_backupvolume() {
      local pvc_name=$1
      local namespace=$2
      local pv_name=$3
      local backup_path=$5
      store_pvc_resources "${pvc_name}" "${namespace}" "${pv_name}" "${volumeattachment_name}"
      sleep 5
      delete_pvc_resources "${pv_name}" "${volumeattachment_name}"
      sleep 5
      create_volume "${pv_name}" "${backup_path}"
      sleep 10
      kubectl create -f "${LOCAL_RESTORE_PATH}/${pv_name}"-pv.json
      if [[ -n "${create_volume_status}" && "${create_volume_status}" != "succeed" ]]; then
        echo "Backup volume restore failed for pvc ${pvc_name} in namespace ${namespace}"
        restore_pvc_status="failed"
      else
        local pvc_uid=""
        pvc_uid=$(kubectl -n "${namespace}" get pvc "${pvc_name}" -o json| jq -r ".metadata.uid")
        # update pv with pvc uid
        kubectl patch pv "${pv_name}" --type json -p "[{\"op\": \"add\", \"path\": \"/spec/claimRef/uid\", \"value\": \"${pvc_uid}\"}]"
        wait_pvc_bound "${namespace}" "${pvc_name}"
        echo "${result}"
      fi
      echo ${restore_pvc_status}
    function restore_pvc(){
      local pvc_name=$1
      local namespace=$2
      local pv_name=$3
      restore_pvc_status="succeed"
      restore_with_backupvolume "${pvc_name}" "${namespace}" "${pv_name}" "${volumeattachment_name}" "${backup_path}"
      # attach_volume "${pv_name}"
    function get_backup_list_by_pvname(){
      local pv_name=$1
      local get_backup_list_by_pvname_resp=""
      local backup_list_response=""
      local try=0
      local maxtry=3
        backup_list_response=$(curl --noproxy "*" "${LONGHORN_URL}/v1/backupvolumes/${pv_name}?action=backupList" -X 'POST' -H 'Content-Length: 0' -H 'Accept: application/json')
        if [[ -n "${backup_list_response}" && "${backup_list_response}" != " " && -n $( echo "${backup_list_response}"|jq ".data" )  && -n $( echo "${backup_list_response}"|jq ".data[]" ) ]]; then
          echo "Backup List Response: ${backup_list_response}"
          # pick first backup data with url non empty
          get_backup_list_by_pvname_resp=$(echo "${backup_list_response}"|jq -c '[.data[]|select(.url | . != null and . != "")][0]')
          break;
        fi
        try=$((try+1))
        sleep 10
      done
      export PV_BACKUP_PATH="${get_backup_list_by_pvname_resp}"
    function get_pvc_resources() {
      get_pvc_resources_resp=""
      local PVC_NAME=$1
      local PVC_NAMESPACE=$2
      # PV have one to one mapping with PVC
      PV_NAME=$(kubectl -n "${PVC_NAMESPACE}" get pvc "${PVC_NAME}" -o json|jq -r ".spec.volumeName")
      VOLUME_ATTACHMENT_LIST=$(kubectl get volumeattachments -n "${PVC_NAMESPACE}" -o=json|jq -c ".items[]|\
    {name: .metadata.name, pvClaimName:.spec.source| select( has (\"persistentVolumeName\")).persistentVolumeName}")
      VOLUME_ATTACHMENT_NAME=""
      for VOLUME_ATTACHMENT in ${VOLUME_ATTACHMENT_LIST};
      do
        PV_CLAIM_NAME=$(echo "${VOLUME_ATTACHMENT}"|jq -r ".pvClaimName")
        if [[ "${PV_NAME}" = "${PV_CLAIM_NAME}" ]]; then
          VOLUME_ATTACHMENT_NAME=$(echo "${VOLUME_ATTACHMENT}"|jq -r ".name")
          break;
        fi
      done
      BACKUP_PATH=""
      validate_pv_backup_available "${PV_NAME}"
      local is_backup_available=${IS_BACKUP_AVAILABLE:- 0}
      unset IS_BACKUP_AVAILABLE
      if [ "${is_backup_available}" -eq 1 ]; then
        echo "Backup is available for PVC ${PVC_NAME}"
        get_backup_list_by_pvname "${PV_NAME}"
        BACKUP_PATH=$(echo "${PV_BACKUP_PATH}"| jq -r ".url")
        unset PV_BACKUP_PATH
      fi
      get_pvc_resources_resp="{\"pvc_name\": \"${PVC_NAME}\", \"pv_name\": \"${PV_NAME}\", \"volumeattachment_name\": \"${VOLUME_ATTACHMENT_NAME}\", \"backup_path\": \"${BACKUP_PATH}\"}"
      echo "${get_pvc_resources_resp}"
    function scale_ownerreferences() {
      local ownerReferences=$1
      local namespace=$2
      local replicas=$3
      # no operation required
      if [[ -z "${ownerReferences}" || "${ownerReferences}" == "null" ]]; then
        return
      fi
      ownerReferences=$(echo "${ownerReferences}"| jq -c ".[]")
      for ownerReference in ${ownerReferences};
      do
        echo "Owner: ${ownerReference}"
        local resourceKind
        local resourceName
        resourceKind=$(echo "${ownerReference}"| jq -r ".kind")
        resourceName=$(echo "${ownerReference}"| jq -r ".name")
        if kubectl -n "${namespace}" get "${resourceKind}" "${resourceName}" >/dev/null 2>&1; then
          # scale replicas
          kubectl  -n "${namespace}" patch "${resourceKind}" "${resourceName}" --type json -p "[{\"op\": \"replace\", \"path\": \"/spec/members\", \"value\": ${replicas} }]"
        fi
      done
    function scale_down_statefulset() {
      local statefulset_name=$1
      local namespace=$2
      local ownerReferences=$3
      echo "Start Scale Down statefulset ${statefulset_name} under namespace ${namespace}..."
      # validate and scale down ownerreference
      scale_ownerreferences "${ownerReferences}" "${namespace}" 0
      local try=0
      local maxtry=30
      success=0
        result=$(kubectl scale statefulset "${statefulset_name}" --replicas=0 -n "${namespace}") || true
        echo "${result}"
        scaledown=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}"|grep 0/0) || true
        if { [ -n "${scaledown}" ] && [ "${scaledown}" != " " ]; }; then
          echo "Statefulset scaled down successfully."
          success=1
          break
        else
          try=$((try+1))
          echo "waiting for the statefulset ${statefulset_name} to scale down...${try}/${maxtry}";sleep 30
        fi
      done
      if [ ${success} -eq 0 ]; then
        echo "Statefulset ${statefulset_name} scaled down failed"
      fi
    function scale_up_statefulset() {
      local namespace=$2
      local replica=$3
      local ownerReferences=$4
      # Scale up statefulsets using PVCs
      echo "Start Scale Up statefulset ${statefulset_name}..."
      # validate and scale up ownerreference
      scale_ownerreferences "${ownerReferences}" "${namespace}" "${replica}"
      echo "Waiting to scale up statefulset..."
      local try=1
      local maxtry=15
      local success=0
        kubectl scale statefulset "${statefulset_name}" --replicas="${replica}" -n "${namespace}"
        scaleup=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}"|grep "${replica}"/"${replica}") || true
        if ! { [ -n "${scaleup}" ] && [ "${scaleup}" != " " ]; }; then
          try=$((try+1))
          echo "waiting for the statefulset ${statefulset_name} to scale up...${try}/${maxtry}"; sleep 30
        else
          echo "Statefulset scaled up successfully."
          success=1
          break
        fi
      done
        echo "Statefulset scaled up failed ${statefulset_name}."
      fi
    function restore_pvc_attached_to_statefulsets() {
      local namespace
      namespace="${1}"
      local statefulset_list
      # list of all statefulset using PVC
      statefulset_list=$(kubectl get statefulset -n "${namespace}" -o=json | jq -r ".items[] | select(.spec.volumeClaimTemplates).metadata.name")
      for statefulset_name in ${statefulset_list};
      do
        local replica
        local pvc_restore_failed
        local try=0
        local maxtry=5
        local status="notready"
        pvc_restore_failed=""
        restore_pvc_status=""
        # check if statefulset is reday
        while [[ "${status}" == "notready" ]] && (( try < maxtry )); do
          echo "fetch statefulset ${statefulset_name} metadata...  ${try}/${maxtry}"
          try=$(( try + 1 ))
          replica=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}" -o=json | jq -c ".spec.replicas")
          if [[ "${replica}" != 0 ]]; then
            status="ready"
          else
            echo "statefulset ${statefulset_name} replica is not ready. Wait and retry"; sleep 30
          fi
        done
        if [[ "${status}" != "ready" ]]; then
          echo "Failed to restore pvc for Statefulset ${statefulset_name} in namespace ${namespace}. Please retrigger volume restore step."
        fi
        # Fetch ownerReferences and claim name
        ownerReferences=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}" -o=json | jq -c ".metadata.ownerReferences")
        claimTemplatesName=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}" -o=json | jq -c ".spec | select( has (\"volumeClaimTemplates\") ).volumeClaimTemplates[].metadata.name " | xargs)
        echo "Scaling down Statefulset ${statefulset_name} with ${replica} under namespace ${namespace}"
        scale_down_statefulset "${statefulset_name}" "${namespace}" "${ownerReferences}"
        for name in ${claimTemplatesName}; do
          local pvc_prefix
          pvc_prefix="${name}-${statefulset_name}"
          for((i=0;i<"${replica}";i++)); do
            local pvc_name
            pvc_name="${pvc_prefix}-${i}"
            pvc_exist=$(kubectl -n "${namespace}" get pvc "${pvc_name}") || true
            if [[ -z "${pvc_exist}" || "${pvc_exist}" == " " ]]; then
              echo "PVC not available for the statefulset ${statefulset_name}, skipping restore."
              continue;
            fi
            local pvc_storageclass
            pvc_storageclass=$(kubectl -n "${namespace}" get pvc "${pvc_name}" -o json| jq -r ".spec.storageClassName")
            if [[ ! ( "${pvc_storageclass}" == "${STORAGE_CLASS}" || "${pvc_storageclass}" == "${STORAGE_CLASS_SINGLE_REPLICA}" ) ]]; then
              echo "backup not available for pvc ${pvc_name}, storageclass: ${pvc_storageclass} "
              continue;
            fi
            # get pv, volumeattachments for pvc
            get_pvc_resources "${pvc_name}" "${namespace}"
            local pv_name
            local backup_path
            pv_name=$(echo "${get_pvc_resources_resp}"| jq -r ".pv_name")
            volumeattachment_name=$(echo "${get_pvc_resources_resp}"| jq -r ".volumeattachment_name")
            backup_path=$(echo "${get_pvc_resources_resp}"| jq -r ".backup_path")
            if [[ -z "${backup_path}" || "${backup_path}" == " " || "${backup_path}" == "null" ]]; then
              pvc_restore_failed="error"
              FAILED_PVC_LIST="${FAILED_PVC_LIST},${pv_name}"
              continue;
            fi
            restore_pvc "${pvc_name}" "${namespace}" "${pv_name}" "${volumeattachment_name}" "${backup_path}"
            if [[ -n "${restore_pvc_status}" && "${restore_pvc_status}" != "succeed" ]]; then
              continue;
            fi
          done
        done
        sleep 10
        scale_up_statefulset "${statefulset_name}" "${namespace}" "${replica}" "${ownerReferences}"
        sleep 5
        if [[ -n "${pvc_restore_failed}" && "${pvc_restore_failed}" == "error" ]]; then
            echo "Failed to restore pvc for Statefulset ${statefulset_name} in namespace ${namespace}."
        fi
      done
    LONGHORN_URL=$(kubectl -n longhorn-system get svc longhorn-backend -o jsonpath="{.spec.clusterIP}"):9500
    restore_pvc_attached_to_statefulsets "mongodb"#!/bin/bash
    set -eu
    FAILED_PVC_LIST=""
      local pv_name=$1
      sleep 2
      sleep 2
        sleep 5
      fi
      local pv_name=$1
        return
      fi
      local success=0
      local try=0
      local maxtry=10
        local result=""
        echo "${result}"
        echo "${result}"
          success=1
          break;
        fi
        try=$(( try + 1 ))
      done
      fi
      local pv_name=$1
      local success=0
      local try=0
      local maxtry=10
        echo "${result}"
        echo "${result}"
          success=1
          break;
        fi
        try=$(( try + 1 ))
      done
      fi
      local pv_name=$1
      local try=0
      local maxtry=3
          else
              break;
            fi
          fi
        fi
        try=$((try+1))
        sleep 10
      done
      local pvc_name=$1
      local namespace=$2
      local pv_name=$3
        echo "${result}"
      fi
      local namespace=$1
      local pvc_name=$2
      try=0
      maxtry=30
        local status=""
          break;
        fi
        try=$((try+1))
      done
      local pv_name=$1
      local response
      local accessmode
      local replicacount
      sleep 5
        local try=0
        local maxtry=480
        local success=0
            # update label
            success=1
            break
          fi
          try=$(( try + 1 ))
        done
        fi
      else
      fi
      local pvc_name=$1
      local namespace=$2
      local pv_name=$3
      sleep 5
      sleep 5
      sleep 10
      else
        local pvc_uid=""
        echo "${result}"
      fi
      local pvc_name=$1
      local namespace=$2
      local pv_name=$3
      local pv_name=$1
      local try=0
      local maxtry=3
          break;
        fi
        try=$((try+1))
        sleep 10
      done
      local PVC_NAME=$1
      do
          break;
        fi
      done
      BACKUP_PATH=""
      fi
      local namespace=$2
      local replicas=$3
        return
      fi
      do
        local resourceKind
        local resourceName
          # scale replicas
        fi
      done
      local namespace=$2
      local try=0
      local maxtry=30
      success=0
        echo "${result}"
          success=1
          break
        else
          try=$((try+1))
        fi
      done
      fi
      local namespace=$2
      local replica=$3
      local try=1
      local maxtry=15
      local success=0
          try=$((try+1))
        else
          success=1
          break
        fi
      done
      fi
      local namespace
      namespace="${1}"
      do
        local replica
        local try=0
        local maxtry=5
          try=$(( try + 1 ))
            status="ready"
          else
          fi
        done
        fi
          local pvc_prefix
            local pvc_name
              continue;
            fi
              continue;
            fi
            local pv_name
            local backup_path
              continue;
            fi
              continue;
            fi
          done
        done
        sleep 10
        sleep 5
        fi
      done
  • Description
  • Solution
