- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
Preparation
Cluster Cleanup
- Copy and run the dedicated script to uninstall everything from that node. Do this for all the nodes. For details, see Troubleshooting.
- Restore all UiPath databases to the backup created before the upgrade.
