- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
Disabling or changing the AD integration settings does not update the underlying directory connections properly.
Run the following command to update the SQL
DirectoryConnections
table entries, then restart the Identity pods:
UPDATE [identity].[DirectoryConnections] SET IsDeleted = 1, DeletionTime=GETUTCDATE() WHERE (Type='ad' OR Type='ldapad') AND IsDeleted=0
