- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
MongoDB monitoring dashboard is a Grafana dashboard for monitoring MongoDB resources and health in the Automation Suite environment.
Note: You cannot bring your own MongoDB.
Before you start, download the MongoDB Monitoring Dashboard 2021.10.1 file from here. After clicking on the download link, the JSON file will open in your browser. To download the file to your local drive, right-click on the page and click Save as....
symbol on the left and then on Create.
