OUT OF SUPPORT
Last updated Feb 24, 2025
Configuring the Machines
Configuring the disk
Important:
  • To prevent data loss, ensure the infrastructure you use does not automatically delete cluster disks on cluster reboot or shutdown. If this capability is enabled, make sure to disable it.
  • To ensure a smooth and uninterrupted SSH session, we strongly recommend that you follow the steps in Installation best practices before configuring the disks and installing Automation Suite.
You can configure and partition the disks using the configureUiPathDisks.sh script. For details, see the following sections.
Disk Requirements
Before the installation, you must partition and configure the disk using LVM, so that its size can be altered easily and without any data migration or data loss.
Disk partitioning
The default partitioning structure on RHEL machines is not suitable for installing Kubernetes. This is because Kubernetes infrastructure is usually installed under the /var partition. By default, the var partition is allocated only 8 GiB of space.
Note:
The supported format for disk is ext4 or xfs.
All partitions must be created using LVM. This is to ensure that cluster data can reside on a different disk, but still be able to be viewed coherently. This also helps in extending the partition size in the future without the risk of data migration or data loss.
For the RHEL OS, you need to ensure you have the following minimum mount point sizes on the machine.
Online
Disk label
Partition
Size
Purpose
Cluster disk
/var/lib/rancher
190 GiB
Rancher folder stores container images and layers
/var/lib/kubelet
56 GiB
Kubelet folder stores runtime Kubernetes configurations such as secrets, configmaps, and emptyDir
/opt/UiPathAutomationSuite
10 GiB
Installer binary
etcd disk
/var/lib/rancher/rke2/server/db
16 GiB
Distributed database for Kubernetes
Data disk
/datadisk
512 GiB (Basic installation)
Block storage abstraction
2 TiB (Complete installation)
Note:
We recommend that you do not use OS disk for any of the above purposes, to ensure processes get their fair share of resources.
Offline
Note:
The requirements for offline are the same as the ones for online, except for the first machine where you run the install on, which needs the following requirements.
The extra space is needed to unpack the offline bundle.
Disk label
Partition
Size
Purpose
Cluster disk
/var/lib/rancher
190 GiB
/var/lib/kubelet
56 GiB
10 GiB
Installer binary
etcd disk
16 GiB
Data disk
/datadisk
UiPath bundle disk
/uipath
512 GiB
Air-gapped bundle
Note:
Note:
Data and etcd disks must be separate physical disks. This physically isolates the data and etcd disks from other cluster workload and activity while also enhancing the performance and stability of the cluster.
See the following section for details on how to use the sample script to partition and configure the disk before the installation.
Using the Script to Configure the Disk
Downloading the script
Note: For offline installations, you must perform this step on a machine with access to internet and to the air-gapped machines where Automation Suite is deployed. Copy the file from the online machine to the first target machine.
You can use the configureUiPathDisks.sh script to configure and partition the disk.
For download instructions, see configureUiPathDisks.sh.
Running the script
You can use the configureUiPathDisks.sh script for the following purposes:
  • configure the disks and mount points for a new Automation Suite cluster installation;
  • resize the data disk post-installation.
To make the script executable, run:
chmod +x ./configureUiPathDisks.shchmod +x ./configureUiPathDisks.sh
For more details on the script usage, run the following command:
sudo ./configureUiPathDisks.sh --helpsudo ./configureUiPathDisks.sh --help
Utility to configure the disk for UiPath Automation Suite Installation.
Run this script to configure the disks on new machine or to extend the size of datadisk
Arguments
  -n|--node-type                  NodeType, Possible values: agent, server. Default to server
  -i|--install-type               Installation mode, Possible values: online, offline. Default to online
  -c|--cluster-disk-name          Device to host rancher and  kubelet. Ex: /dev/sdb
  -e|--etcd-disk-name             Device to host etcd, Not required for agent node. Ex: /dev/sdb
  -l|--data-disk-name             Device to host datadisk, Not required for agent node. Ex: /dev/sdc
  -b|--bundle-disk-name           Device to host the uipath bundle.
                                    Only required for offline installation on 1st server node
  -f|--complete-suite             Installing complete product suite or any of these products:
                                    aicenter, apps, taskmining, documentunderstanding.
                                    This will configure the datadisk volume to be 2TiB instead of 512Gi.
  -p|--primary-server             Is this machine is first server machine? Applicable only for airgap install.
                                    This is the machine on which UiPath AutomationSuite bundle will be installed.
                                    Default to false
  -x|--extend-data-disk           Extend the datadisk. Either attach new disk or resize the exiting datadisk
  -r|--resize                     Used in conjunction of with --extend-data-disk to resize the exiting volume,
                                    instead of adding new volume
  -d|--debug                      Run in debug
  -h|--help                       Display help
ExampleUsage:
  configureUiPathDisks.sh --node-type server --install-type online \
    --cluster-disk-name /dev/sdb --etcd-disk-name /dev/sdc \
    --data-disk-name /dev/sdd
  configureUiPathDisks.sh --data-disk-name /dev/sdh --extend-data-disk
Arguments
                                    Default to false
ExampleUsage:
Configuring the Disk for a Multi-node HA-ready Production Setup
Online
Server nodes
To configure the disk in an online multi-node HA-ready production setup, run the following command on all server machines:
./configureUiPathDisks.sh --cluster-disk-name name_of_cluster_disk \
  --etcd-disk-name name_of_etcd_disk \
  --data-disk-name name_of_data_disk./configureUiPathDisks.sh --cluster-disk-name name_of_cluster_disk \
Agent nodes
To configure the disk in an online multi-node HA-ready production setup, run the following command on all agent machines:
  --node-type agent./configureUiPathDisks.sh --cluster-disk-name name_of_cluster_disk \
  --node-type agent
Offline
First server node
In an offline installation, you need to load the product’s images in the docker registry. For that, additional storage in the form of a separate disk is required. This disk will be used to un-tar product bundles and upload images to the docker registry. It is required to be present only on the first machine.
Set the --primary-server flag on the first server machine or on the machine on which the fabric and service installer will run.
To configure the disk in an offline multi-node HA-ready production setup, run the following command on the first server machine:
  --data-disk-name name_of_data_disk \
  --bundle-disk-name name_of_uipath_bundle_disk \
  --primary-server \
  --install-type offline./configureUiPathDisks.sh --cluster-disk-name name_of_cluster_disk \
  --primary-server \
Additional server nodes
On the server nodes, you do not need the bundle disk. Therefore, you do not need to provide the --primary-server and --bundle-disk-name.
To configure the disk in an offline multi-node HA-ready production setup, run the following command on the other server machines:
Agent nodes
To configure the disk in an offline multi-node HA-ready production setup, run the following command on the other agent machines.
  --node-type agent \
  --node-type agent \
Extending the data disk post-installation
To extend the data disk, you can attach the new physical disk or resize the existing disk.
Adding a new disk
To extend the data disk using the newly attached disk, run the following command on the server machines:
./configureUiPathDisks.sh --data-disk-name name_of_data_disk \
  --extend-data-disk./configureUiPathDisks.sh --data-disk-name name_of_data_disk \
  --extend-data-disk
Resizing the existing disk
To extend the data disk by resizing the existing disk, run the following command on the server machines:
./configureUiPathDisks.sh --extend-data-disk --resize./configureUiPathDisks.sh --extend-data-disk --resize
Validating disk mounts
  1. Take the following steps to validate /etc/fstab is correctly configured to handle rebooting of system.
    Note:
    Make sure that etcd and datadisk mount points are added in the fstab file.
    If you have separate disk partition for /var/lib/rancher and /var/lib/kubelet, then fstab should also contain these two folders. Also make sure to include nofail option in those fstab entries so that it does not affect the VM boot in case of failures.
  2. Validate the disks are mounted correctly by running the following command:
    mount -afvmount -afv
  3. You should get the following response:
    /datadisk                              : already mounted
    /var/lib/rancher/rke2/server/db        : already mounted
    /var/lib/rancher                       : already mounted
    /var/lib/kubelet                       : already mounted/datadisk                              : already mounted
Configuring kernel and OS level settings
The following page helps Linux administrators on managing OS and kernel level settings before performing an Automation Suite installation.
Usually, these settings are managed via a dedicated management configuration tool, such as Puppet. Make sure that the changes you make are according to the control process of your environment for consistency and documentation purposes.
Important:
Make sure to complete the following steps before starting the installation, as misconfigurations at the OS and kernel level can lead to non-intuitive errors. Checking these specific settings can often avoid such errors.
Configuring sysctl settings
The following sysctl settings are required on the machine:
  • enable IP forwarding
  • disable reverse path filtering
You can do this by running the following command:
cat <<EOF >>"/etc/sysctl.d/99-sysctl.conf"
net.bridge.bridge-nf-call-iptables = 1
net.ipv4.ip_forward = 1
net.bridge.bridge-nf-call-ip6tables = 1
net.ipv4.conf.all.rp_filter=0
EOFcat <<EOF >>"/etc/sysctl.d/99-sysctl.conf"
EOF
Note: The nf-call-iptables is needed for most Kubernetes deployments. Kubernetes creates virtual networks internal to the cluster. This allows every pod to have its own IP address, which is used in conjunction with the internal name services to facilitate service-to-service communication. The cluster does not work without nf-call-iptables enabled. For details, see the official Kubernetes documentation.
To apply the settings, run the following command:
sysctl --systemsysctl --system
Configuring fapolicy settings
Important:
This step is optional and applies only if you use fapolicy. In this case, an RKE2 specific policy is required.
To generate the RKE2 policy, use the following command:
cat <<-EOF >>"/etc/fapolicyd/rules.d/69-rke2.rules"
allow perm=any all : dir=/var/lib/rancher/
allow perm=any all : dir=/opt/cni/
allow perm=any all : dir=/run/k3s/
allow perm=any all : dir=/var/lib/kubelet/
allow perm=any all : dir=/root/.local/share/helm
EOFcat <<-EOF >>"/etc/fapolicyd/rules.d/69-rke2.rules"
EOF
Note:
Ensure that the change is communicated to your Linux team and goes through the appropriate configuration management processes.
Configuring noexec and nosuid settings
The disks used for the /var/lib/rancher mount must not have noexec or nosuid set. The disk tool automatically creates these mounts without these properties.
Important:
If a Linux administrator manually sets these properties, the instance becomes non-functional.
For more details on disk configuration, see Disk Requirements.
Enabling Ports
Make sure that you have the following ports enabled on your firewall for each source.
Port
Protocol
Source
Purpose
Requirements
22
TCP
Jump Server / client machine
For SSH (installation, cluster management debugging)
Do not open this port to the internet. Allow access to client machine or jump server.
80
TCP
Offline installation only: required for sending system email notifications.
443
TCP
All nodes in a cluster + load balancer
For HTTPS (accessing Automation Suite)
This port should have inbound and outbound connectivity from all the nodes in the cluster and the load balancer.
587
TCP
2379
TCP
etcd client port
Must not expose to the internet. Access between nodes should be enough over a private IP address.
2380
TCP
etcd peer port
6443
TCP
For accessing Kube API using HTTPS, and required for node joining
This port should have inbound and outbound connectivity from all nodes in the cluster.
8472
UDP
Required for Flannel (VXLAN)
9345
TCP
For accessing Kube API using HTTP, required for node joining
This port should have inbound and outbound connectivity from all nodes in the cluster and the load balancer.
10250
TCP
kubelet / metrics server
30071
TCP
NodePort port for internal communication between nodes in a cluster
Important:
Exposing port 6443 outside the cluster boundary is mandatory if there is a direct connection to the Kerberos API.
Port 9345 is used by nodes to discover existing nodes and join the cluster in the multi-node deployment. To keep the high availability discovery mechanisms running, we recommend exposing it via the load balancer with health check.
Also ensure you have connectivity from all nodes to the SQL server.
Do not expose the SQL server on one of the Istio reserved ports, as it may lead to connection failures.
If you have a firewall setup in the network, make sure that it has these ports open and allows traffic according to the requirements mentioned above.
Optional: Configuring the proxy server
To configure a proxy, you need to perform additional configuration steps while setting up your environment with the prerequisites and during the advanced configuration phase of installation time.
The following steps are required when setting up your environment.
Note: We currently do not support HTTPS proxy with self-signed certificates. Make sure you use a public trusted certificate if you are configuring the proxy.
Step 1: Enabling ports on the virtual network
Make sure that you have the following rules enabled on your network security group for the given Virtual Network.
Source
Destination
Route via proxy
Port
Virtual Network
SQL
No
SQL server port
Required for SQL Server.
Virtual Network
Load Balancer
No
9345
6443
Required to add new nodes to the cluster.
Virtual Network
Cluster(subnet)
No
All ports
Required for communication over a private IP range.
Virtual Network
alm.<fqdn>
No
443
Required for login and using ArgoCD client during deployment.
Virtual Network
Proxy Server
Yes
All ports
Required to route traffic to the proxy server.
Virtual Network
NameServer
No
All ports
Most of the cloud services such as Azure and AWS use this to fetch the VM metadata and consider this a private IP.
Virtual Network
MetaDataServer
No
All ports
Most of the cloud services such as Azure and AWS use the IP address 169.254.169.254 to fetch machine metadata.
Step 2: Adding proxy configuration to each node
When configuring the nodes, you need to add the proxy configuration to each node that is part of the cluster. This step is required to route outbound traffic from the node via the proxy server.
  1. Add the following configuration in /etc/environment:
    http_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT>
    https_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT>
    no_proxy=alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>,<private_subnet_ip>,localhost,<Comma separated list of ips that should not got though proxy server>http_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT>
  2. Add the following configuration in /etc/wgetrc:
    Mandatory parameters
    http_proxy
    Used to route HTTP outbound requests from the node. This should be the proxy server FQDN and port.
    https_proxy
    Used to route HTTPS outbound requests from the node. This should be the proxy server FQDN and port.
    no_proxy
    Comma-separated list of hosts, IP addresses that you do not want to route via the proxy server. This should be a private subnet, SQL server host, named server address, metadata server address: alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>.
    • metadata server address – Most of the cloud services such as Azure and AWS use the IP address 169.254.169.254 to fetch machine metadata.
    • named server address – Most of the cloud services such as Azure and AWS use this to resolve DNS query.
  3. Verify if the proxy settings are properly configured by running the following command:
    curl -v $HTTP_PROXY
    curl -v <fixed_rke_address>:9345curl -v $HTTP_PROXY
    Important: Once you meet the proxy server requirements, make sure to continue with the proxy configuration during installation. Follow the steps in Optional: Configuring the proxy server to ensure the proxy server is set up properly.
