- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Orchestrator Configuration File Checklist
- Pre-migration steps
- Updating the Database Connection Strings
- Post-migration steps
- B) Single Tenant Migration
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Make sure to create a backup of the original Orchestrator and Identity Server databases' connection strings of the Automation Suite deployment. To prevent data loss when creating the backup, close all open sessions or connections to UiPath products and services.
There are cases where multiple services (e.g., Orchestrator and Identity Server) share the same database in your standalone setup whereas Automation Suite automatically creates separate databases for them as part of the migration process.
In this case, after backing up your shared database in your standalone environment, you need to provide its connection string for the newly created, separate databases in Automation Suite. This should result in two different databases with the same connection string.
Make sure you are using multiple databases for the platform services instead of a single one. Use the advanced deployment option for that. Simplified Automation Suite deployment creates a single database for all of Automation Suite's shared services and capabilities (e.g., Identity Server, Location, Audit, etc.) whereas the standalone deployment only features Identity Server and is not aware of other services.
Once you restore the standalone Orchestrator database backup to Automation Suite’s SQL Server, you need to update the connection strings using ArgoCD. Take the following steps:
