  • Release notes
    • 2023.10.12
    • 2023.10.11
    • 2023.10.10
    • 2023.10.9
    • 2023.10.8
    • 2023.10.7
    • 2023.10.6
    • 2023.10.5
    • 2023.10.4
    • 2023.10.3
    • 2023.10.2
    • 2023.10.1
    • 2023.10
  • Before you begin
    • Installing Automation Suite
    • Process Mining configuration checklist
    • System requirements
  • Getting started
    • Introduction to Process Mining
    • Process Mining
    • Architecture overview
    • Process Mining portal
    • Uploading app templates
    • Migrating apps for use in Process Mining
    • Managing access
      • Enabling Process Mining
      • Setting up the users
      • Managing access for process apps
  • Integrations
    • Setting up Automation integration
  • Working with process apps
    • Working with dashboards and charts
    • Working with process graphs
    • Working with Discover process models and Import BPMN models
    • Showing or hiding the menu
    • Context information
    • Export
    • Filters
    • Sending automation ideas to UiPath® Automation Hub
    • Tags
    • Due dates
    • Compare
    • Conformance checking
    • Root cause analysis
    • Simulating automation potential
    • Triggering an automation from a process app
    • Viewing Process data
  • Creating apps
    • App Templates
    • Migrating apps for the new process graph layout
    • Create new app wizard
      • Scenarios
    • Editing app settings
      • Setting data restrictions for a process app
    • Cloning an app
    • Deleting an app
    • Exporting and importing process apps
  • Loading data
    • Uploading data
    • Retrieving the SQL Server database parameters
    • Setting up a SQL Server account for data upload using an extractor
    • Loading data using CData Sync
      • Installing CData Sync
      • Create a source connection
      • Create a destination connection
      • Create a job
      • Run the job
      • Incremental extraction
      • Troubleshooting CData Sync
    • Loading data using Theobald Xtract Universal
      • Setting up Theobald Xtract Universal
      • Importing the template extractions
      • Configuring the source
      • Configuring the destination
      • Configuring the extraction script
      • Running the extraction script
      • Troubleshooting
    • Viewing logs
    • Optimizing an app
    • Scheduling Data Runs
  • Customizing process apps
    • Introduction to dashboards
    • Working with the dashboard editor
    • Creating dashboards
    • Dashboards
    • Charts
      • Bar charts
      • Distribution charts
      • Table charts
      • Line charts
      • Process graphs
      • KPI trends lists
      • Pie charts
    • Data manager
      • Fields
      • Metrics
    • Automation manager
    • Data transformations
      • Defining new input tables
      • Adding fields
      • Adding tables
      • Data model requirements
      • Viewing and editing the data model
      • Exporting and importing transformations
      • Viewing the transformations log
      • Editing and testing data transformations
      • Structure of transformations
      • Tips for writing SQL
      • Merging event logs
    • Process manager
  • Publishing Dashboards
  • App templates
    • Event log and Custom process app templates
      • Overview of generic menus and dashboards
      • Menu Overview
      • Menu Analysis
        • Analysis - End to end
        • Analysis - Event analysis
      • Event log input fields
      • Custom process input fields
      • Configuring CData Sync for Event log or Custom process
    • Purchase-to-Pay app template
      • Introduction to Purchase-to-Pay Process App
      • Overview of menus and dashboards
      • Menu Summary
      • Menu Analysis
        • Analysis - End to end process
      • Menu Efficiency
        • Efficiency - Supplier performance
      • Menu Compliance
        • Compliance - Maverick buying
      • Purchase-to-Pay input fields
      • Configuring CData Sync for Purchase-to-Pay
    • Order-to-Cash app template
      • Introduction to Order-to-Cash Process App
      • Menu Summary
      • Menu Analysis
        • Analysis - Event Analysis
      • Menu Efficiency
        • Efficiency - Customers
      • Order-to-Cash input fields
      • Configuring CData Sync for Order-to-Cash
  • Additional resources
    • Out-of-the-box Tags and Due dates
    • Editing data transformations in a local environment
    • Setting up a local test environment
    • Transformations
      • Custom throughput time metrics
      • SQL differences between Snowflake and SQL Server
      • Configuration settings for loading input data
    • Designing an event log
    • Loading data using DataBridgeAgent
      • Introduction
        • Using .mvp Connectors
        • Downloading DataBridgeAgent
      • DataBridgeAgent
      • Prerequisites
        • Setup credentials for the SQL Server database
        • Extracting data from an SAP source system
        • Extracting data via loading .csv files
        • Extracting data via an ODBC connection
        • Using a Credential store
      • Configuring DataBridgeAgent
      • Adding a custom connector to DataBridgeAgent
      • Using DataBridgeAgent with SAP Connector for Purchase-to-Pay Discovery Accelerator
      • Using DataBridgeAgent with SAP Connector for Order-to-Cash Discovery Accelerator
    • Extending the SAP Ariba extraction tool
    • Performance characteristics
    • Basic troubleshooting guide
      • How to cancel a data run from the database
      • How to add an IP table rule to use SQL Server port 1433
      • When creating a process app the status stays in Creating app
      • Configuring Dapr with Redis in cluster mode
      • Uploading data
      • CData Sync
Process Mining
Last updated Jan 15, 2026
2023.10.12
Release date: November 6, 2025
This release brings security updates to address CVE-2025-55315. Refer to the UiPath Trust Center for more information.
  • Release date: November 6, 2025
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
