- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
You can get the Automation Suite Support Bundle tool in the following ways:
- By unzipping the as-installer.zip installer package
- By downloading the supportability-tools.zip
Before running the Automation Suite Support Bundle tool, navigate to the installer folder. You can find the installer in the following location or anywhere you downloaded it:
cd /opt/UiPathAutomationSuite/{version}/installercd /opt/UiPathAutomationSuite/{version}/installerTo start using the Automation Suite Support Bundle tool, run the following commands:
cd ./Support-Tools/support-bundle
./support-bundle.shcd ./Support-Tools/support-bundle
./support-bundle.shThe following image shows a typical output for this command:
Running only
bash support-bundle.shcollects logs for the last 2 days from the S3-compatible objectstore, if you use an external objectstore, or from Ceph, if you use the in-cluster objectstore. -
To set the start date for the log collection process, use the
-Fargument and enter the date in theYYYY-MM-DDformat. To set the number of days for which you want to collect logs, calculated from the start date, use the-Dargument and enter the number of days as an integer. For example, to collect logs for the interval between July 20, 2024, and July 24, 2024, runbash support-bundle.sh -F 2024-07-20 -D 5.To collect logs for a particular date, use the-Fargument to specify the date and the-Dargument to set an interval of one day. For example, to collect logs for July 20, 2024, runbash support-bundle.sh -F 2024-07-20 -D 1.If you do not set the number of days for which you want to collect logs, the tool uses a default interval of 7 days, calculated from the start date. For example, runningbash support-bundle.sh -F 2024-07-20collects logs for the interval between July 20, 2024, and July 26, 2024. - We collect logs for almost all the namespaces used in Automation Suite. To collect logs only for particular namespaces, run
bash support-bundle.sh -N uipath,uipath-infra. Use-Nas list of namespaces for which you want to collect the logs. - The RKE2, uipath, Redis, and Longhorn bundles are generated by default.
- To disable the RKE2 bundle, run the
support-bundle.sh -ecommand. - Long-running commands in the RKE bundle are disabled. To enable them, run the
scripts/rke2-support-bundle.sh -acommand. - To disable Redis bundle generation, run the
support-bundle.sh -scommand.
- High-level summarized usage telemetry is also exported with this tool generating an XML file. This telemetry includes:
- Robot execution duration per month by robot type.
- Robot concurrency - the maximum number of robots that executed at the same time.
- Metrics on jobs run, processes run, queue items, job failure rate, and users.
- Environment information.
- AI Units usage summary if you use AI Center.
- You can upload the XML file in the Customer Portal to share your high-level self-hosted usage telemetry with the UiPath Support team.
- You can opt out of generating this summarized telemetry by using
-cin the RKE environments for Automation Suite 2023.10 and lower.
.zip archive contains following files and folders:
File/folder |
Description |
Contains logs collected from the S3 store. |
Contains event descriptions from all the namespaces. |
Contains descriptions of all the nodes in the cluster. |
Contains descriptions of corresponding objects from all namespaces. |
Contains last 4 hour logs from currently running pods. We are collecting this to handle the scenario where Ceph S3 store is down. |
Contains high level usage telemetry stored in individual XML files. |
If passed specific namespace list to the command, the structure would look similar to the one shown in the following image:
