Last updated Dec 4, 2025
Guidelines on backing up and restoring an Active/Passive deployment
Note:
For detailed instructions on how to backup and restore Automation Suite, see Backing up and restoring the cluster.
Backing up the cluster
  • You must back up only the primary cluster and external storage (SQL and Objectstore).
  • It is not mandatory to take a backup of the secondary cluster. Instead, you can choose to take a backup of the secondary. However, you can still use the primary cluster to set up the secondary cluster.
Restoring the primary cluster
  • If the primary cluster goes down, you must use the backup to restore it.
  • If you applied a new configuration on the secondary cluster while the primary cluster is down, then at the time of the restore, you can reuse the cluster_config.json file of the secondary cluster and update the critical parameter, which is very specific to the primary cluster, and then you can restore the cluster.
Restoring the secondary cluster
  • If the secondary cluster’s backup is unavailable, you can restore it from the primary cluster by taking the following steps:
    1. Generate the cluster_config.json from the primary cluster.
    2. Update the cluster_config.json with the specific value of the secondary cluster.
    3. Install the secondary cluster.
  • If the backup for the secondary cluster is available, you can restore the secondary cluster from the backup.
  • Backing up the cluster
  • Restoring the primary cluster
  • Restoring the secondary cluster
