- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Last updated Nov 13, 2025
Take the following steps on one of the cluster server nodes:
Obtain Kubernetes access.
on server nodes: export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" on agent nodes: export KUBECONFIG="/var/lib/rancher/rke2/agent/kubelet.kubeconfig" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" # To validate, execute the following command which should not return an error: kubectl get nodeson server nodes: export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" on agent nodes: export KUBECONFIG="/var/lib/rancher/rke2/agent/kubelet.kubeconfig" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" # To validate, execute the following command which should not return an error: kubectl get nodes -
Retrieve the ArgoCD password by running the following command:
kubectl get secrets/argocd-admin-password -n argocd --template '{{ .data.password }}' | base64 -dkubectl get secrets/argocd-admin-password -n argocd --template '{{ .data.password }}' | base64 -d - Connect to ArgoCD.
- Navigate to
https://alm.<fqdn>/:443 - Login using
adminas the username and the password obtained at Step 2. - Locate the UiPath Services application as follows:
- Using the search bar provided in ArgoCD, type in
uipath. - Then open the UiPath® application by clicking its card.
- Check for the following:
Application was not synced due to a failed job/pod. - If the above error exists, take the following steps.
- Locate any un-synced components by looking for the red broken heart icon, as shown in the following image.
- Open the right-most component (usually pods) and click the Logs tab. The Logs will contain an error message indicating the reason for the pod failure.
- Once you resolve any outstanding configuration issues, go back to the home page and click the Sync button on the UiPath® application.
