- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Automation Suite does not support the IPv6 internet protocol.
We do not support firewalld. The Automation Suite installer automatically disables firewalld during installation; make sure it remains in a disabled state post-installation as well.
Automation Suite sets up default IP table rules on the host machines for necessary inter-node communication. We do not support custom IP table rules, such as those configured via firewalld, as they might conflict with IP table rules configured by Automation Suite. You can, however, apply extra firewall rules at the network level.
We recommend enabling firewall applications at the network gateway, but not between clusters.
This page lists the domains used by the various UiPath® products, components, and integrations in an online deployment. You must allow traffic to and from these domains, otherwise Automation Suite may malfunction.
Add to your allow list those endpoints and ports for the UiPath® products and services you use. For example, if you do not have AI Center, there is no need to add its required domains to your allow list.
General requirements
To ensure cluster stability, your environment must meet the following requirements:
- Round Trip Time (RTT) between the nodes must be minimal (<10 ms RTT);
- High Availability requirements must be met.
Installation
- For downloading the required installer files and configuration scripts:
https://download.uipath.com- downloads the installer script - For downloading container images and metadata:
https://registry-data.uipath.comhttps://registry.uipath.comThe previous URLs are required during installation, for adding new nodes to an existing cluster, for upgrading to a newer version, and for application sync using ArogCD. These URLs may also be needed during runtime so that Kubernetes can pull the image.
- For using supportability tools, such as the support bundle generation and diagnostic tools:
https://sfbrprddeploywe.azurecr.iohttps://sfbrprddeploywe.westeurope.data.azurecr.io
- For the installation of Kubernetes or RKE2:
https://rpm.rancher.io - For sending business telemetry to UiPath®:
https://dc.services.visualstudio.comThis is only required if you opt in to send telemetry data to UiPath®.
Shared Platform Capabilities
Automation Suite portal
- For the Azure Active Directory integration:
https://login.microsoftonline.com/* - (Optional) For application insights:
https://dc.services.visualstudio.com/*
Identity
https://login.microsoftonline.com/*https://graph.microsoft.com/*
- For the SQL connection: the connection you use, possibly through a pipeline
- For the Redis connection: the port number and password that are generated during Redis deployment
- For the Active Directory integration:
- Kerberos: port
88 - LDAP endpoints: port
389 - DNS for DC discovery:
port
53
- Kerberos: port
- For SAML authentication: SAML endpoints, as configured for Automation Suite
- For system email notifications: SMTP server and port, as configured for Automation Suite
- For certificate validation on connection, if CRLs need to be downloaded: the endpoint determined by the certificate
Webhooks
- HTTP(S) Webhook endpoints, as defined by users in the Orchestrator Webhook definition
Organization management
- For the Ceph integration: the connection is generated during infrastructure setup
Audit
Licensing
- For online license activation, update, and other online license operations:
https://activate.uipath.com/ - For the SQL connection: the connection you use, possibly through a pipeline
Test Manager
- HTTP(S) calls via the Webhook connector
- HTTP(S) calls to Xray for Jira (on-premises or cloud), to ServiceNow, and to AzureDevOps
AI Center
- The OOB models and metadata are fetched from our GitHub repository, and the models themselves are downloaded from our storage
account. The following URLs cannot be blocked as the OOB scheduler continues to run, and the last three URLs as they are needed
at runtime. Therefore, make sure that you have access to the following:
- The following are needed in order for the OOB metadata to fetch new models being added:
https://github.comhttps://raw.github.comhttps://raw.githubusercontent.comhttps://api.github.com
https://uipath.blob.core.windows.netis needed to clone the new models downloaded- The following are needed at runtime for skill deployment and training pipeline for downloading dependencies:
- The Python Package Index:
http://pypi.python.org/andhttp://pypi.org/ - Any Python PIP hosted public domains, based on your model package and required Python libraries in
requirements.txt
https://du-metering.uipath.comNote:This URL is needed only when AI Center is connected to an external Orchestrator.
https://du.uipath.com
- For OCR:
- The UiPathDocumentOCR endpoint applicable for your region
- Microsoft OCR (optional): The endpoint applicable for your region
- Google OCR (optional):
https://vision.googleapis.com/v1/images:annotate
- For data extraction: the FormExtractor endpoint applicable for your region
Task Mining
- To download desktop clients:
https://download.uipath.com/TaskMining/sf/task-mining-setup.exe(EXE) andhttps://download.uipath.com/TaskMining/sf/task-mining-setup.msi(MSI) - For the SQL connection: the connection you use, possibly through a pipeline
- For the RabbitMQ connection: the connection is generated during infrastructure setup
Insights
Data Service
Runtime URL dependencies
https://activate.uipath.comsmtp.sendgrid.net(or whichever SMTP server is configured)- Any port-level blocks need to be accounted for.
- Any TLS or SSL certificates associated with the SMTP server should be verifiable without the need for a CRL fetch outside your offline environment.
https://dc.services.visualstudio.com/v2/track
Azure dependencies
If you use Azure infrastructure, you must allow the RHEL yum mirrors for Azure listed in this section.
These URLs are strictly applicable for Azure. If you use a different cloud services provider (CSP), the URLs are different.
http://rhui-1.microsoft.comhttp://rhui-2.microsoft.comhttp://rhui-3.microsoft.com- For the Azure Active Directory integration:
Documentation
For your users to be able to access the official UiPath® documentation for Automation Suite and the bundled products, you must also allow documentation-specific URLs. For the full list, see UiPath® Documentation Website URLs.
/etc/sysctl.d/ folder, using the following command:
cat <<EOF >>"/etc/sysctl.d/99-sysctl.conf"
net.bridge.bridge-nf-call-iptables = 1
net.ipv4.ip_forward = 1
net.bridge.bridge-nf-call-ip6tables = 1
EOFcat <<EOF >>"/etc/sysctl.d/99-sysctl.conf"
EOF- The previous command is an OS level setting, and it is recommended to be used only by Linux admins. Ensure the changes you make are according to the control process of your environment.
- The
nf-call-iptablesis needed for most Kubernetes deployments. Kubernetes creates virtual networks internal to the cluster. This allows every pod to have its own IP address, which is used in conjunction with the internal name services to facilitate service-to-service communication. The cluster does not work withoutnf-call-iptablesenabled. For details, see the official Kubernetes documentation.
