- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Managing products
- Setting up the external NFS server
- Configuring the cluster snapshot backup
- Additional configuration
- Restoring the backup
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Last updated Dec 4, 2025
Important:
UiPath® does not provide any specific steps to repave or update the NFS server.
Before updating the NFS server, make sure the backup is disabled. For instructions, see .
Guidelines
It is good practice to back up the disk attached to the NFS server where you create the backup. You can find this information defined as the
nfs.mountpointkey in thebackup.jsonfile. -
To repave the NFS server, take the following steps:
- Mount the backup disk on the newly repaved machine on the same mount point as defined by the
nfs.mountpointkey in thebackup.jsonfile. - Update the NFS endpoint of the new NFS server defined as
nfs.endpointinbackup.json. - After repaving the NFS server, make sure you have followed the Setting up the external NFS server guidance.
Once the update to NFS server is complete, it is recommended to reboot the machine. Also make sure to enable the backup on cluster. For instructions, see .
Adding a new node to the cluster
To add a new node to the cluster, re-run the following steps:
- Add the FQDN or the IP address of the new node to the allowlist of the NFS server. For instructions, see Allowing NFS mount path access to all backup and restore nodes.
- Enable the backup on the new node post-installation. For instructions, see Configuring the cluster snapshot backup.
