Last updated Dec 4, 2025
Setting up Elasticsearch and Kibana
The EFK (Elasticsearch, Fluentd, Kibana) stack is a centralized logging solution that allows you to search, analyze and visualize log data. Fluentd collects and sends the logs to Elasticsearch, Kibana retrieves the logs and lets you visualize and analyze the data.
Automation Suite supports Elasticsearch version 7.x.
Creating a secret with the Elasticsearch password
If your Elasticsearch instance requires credentials, create a secret with its password in the cluster.
kubectl -n cattle-logging-system create secret generic elastic-user --from-literal=password=<password>kubectl -n cattle-logging-system create secret generic elastic-user --from-literal=password=<password>
ClusterOutput to Elasticsearch
Run the following command to ClusterOutput to Elasticsearch. Replace the following attributes with the ones of your Elasticsearch configuration:
  • <elasticsearch host> - the network host of your Elasticsearch instance;
  • <elasticsearch port> - the Elasticsearch port for client communication;
  • <secret key> - the secret with the Elasticsearch password;
  • timekey value in elasticsearch.buffer - the output frequency i.e. how often you want to push logs;
  • elasticsearch.scheme - the URL scheme. Valid values are: http or https.
    kubectl -n cattle-logging-system apply -f - <<"EOF"
    apiVersion: logging.banzaicloud.io/v1beta1
    kind: ClusterOutput
    metadata:
    spec:
      elasticsearch:
        host: <elasticsearch host>
        port: <elasticsearch port>
        scheme: <http or https>
        ssl_verify: false
        ssl_version: TLSv1_2
        user: elastic
        password:
          valueFrom:
            secretKeyRef:
              key: <secret key>
        buffer:
          timekey: 10m
          timekey_wait: 30s
          timekey_use_utc: true
    EOFkubectl -n cattle-logging-system apply -f - <<"EOF"
    kind: ClusterOutput
    metadata:
    spec:
      elasticsearch:
        ssl_verify: false
        user: elastic
        password:
          valueFrom:
            secretKeyRef:
              key: <secret key>
        buffer:
          timekey: 10m
          timekey_wait: 30s
    EOF
ClusterFlow in FluentD
Run the following command to ClusterFlow in FluendD:
kind: ClusterFlow
metadata:
spec:
  filters:
    - tag_normaliser:
        format: ${namespace_name}/${pod_name}.${container_name}
  globalOutputRefs:
    - es-output
  match:
    - select:
        container_names:
          - istio-proxy
        namespaces:
          - istio-system
    - exclude:
        container_names:
          - istio-proxy
          - istio-init
          - aicenter-hit-count-update
    - exclude:
        namespaces:
          - fleet-system
          - cattle-gatekeeper-system
          - default
    - exclude:
        labels:
          app: csi-snapshotter
    - exclude:
        labels:
          longhorn.io/job-task: backup
    - exclude:
        labels:
          app: csi-resizer
    - select: {}
kind: ClusterFlow
metadata:
spec:
  filters:
    - tag_normaliser:
  globalOutputRefs:
    - es-output
  match:
    - select:
        container_names:
          - istio-proxy
        namespaces:
          - istio-system
    - exclude:
        container_names:
          - istio-proxy
          - istio-init
    - exclude:
        namespaces:
          - fleet-system
          - default
    - exclude:
        labels:
    - exclude:
        labels:
    - exclude:
        labels:
          app: csi-resizer
    - select: {}
EOF
Logs from the cluster are collected and logged to the ClusterOutput.
Configuring Kibana
  1. Select Discover under Analytics on the sidebar.
  2. Select Create Index Pattern and then Create an index pattern with name Fluentd.
  3. Select I don’t want to use the time filter on the Configure settings window.
  4. Select Discover under Kibana on the sidebar.
    • You can see logs in the dashboard.
    • Logs query for the UiPath namespace and a specific service:
