Last updated Nov 13, 2025
How to disable TX checksum offloading
Checksum offloading on a network card may cause issues in some setups, including on VMware instances and in Cilium. If you encounter such issues, take the following steps:
  1. Disable TX checksum offloading by running the following commands:
    • For server machines:
      cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service
      [Unit]
      Description=Disable TX Checksum Offload
      Before=rke2-server.service
      Wants=network-online.target
      After=network-online.target
      [Service]
      Type=oneshot
      ExecStart=/bin/bash -c "ethtool -K $(awk '$2 == 00000000 { print $1; exit }' /proc/net/route) tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true"
      RemainAfterExit=true
      [Install]
      WantedBy=multi-user.target
      EOF
      sudo systemctl enable disable-checksumcat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service
      [Unit]
      [Service]
      Type=oneshot
      [Install]
      EOF
    • For agent machines:
      [Unit]
      Before=rke2-agent.service
      [Service]
      Type=oneshot
      [Install]
      EOF
      [Unit]
      [Service]
      Type=oneshot
      [Install]
      EOF
  2. Restart the affected instance by taking the steps described in Starting and shutting down a node.
