uipathctl reference guide
Last updated Apr 28, 2025
uipathctl rke2 registry hydrate-registry
Seed the in-cluster docker-registry from the temporary registry. By default, the seed will be performed for all registry pods.
To seed a specific registry pod, use --cluster-registries argument with required pods's IP. To reduce hydration time, you can increase the number of worker thread by passing --num-worker argument. Please ensure all registry pods are in Running state before performing hydration.
uipathctl rke2 registry hydrate-registry [flags]uipathctl rke2 registry hydrate-registry [flags]
Examples
# Seed all registry pods using configuration found in cluster_config.json
uipathctl rke2 registry hydrate-registry cluster_config.json
# Seed specific registry pod having ip 10.42.0.157
uipathctl rke2 registry hydrate-registry cluster_config.json --cluster-registries 10.42.0.157
# Seed all registry pods with 12 worker count
uipathctl rke2 registry hydrate-registry cluster_config.json --num-worker 12# Seed all registry pods using configuration found in cluster_config.json
Options
--cluster-registries strings   List of cluster-registries ip along with port, if not mentioned then all the registry pods considered
  -h, --help                         help for hydrate-registry
      --num-worker int               Number of workers to seed images in parallel (default 3)      --cluster-registries strings   List of cluster-registries ip along with port, if not mentioned then all the registry pods considered
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
