uipathctl reference guide
Last updated Apr 28, 2025
uipathctl rke2 prereq
Prerequisite check commands.
uipathctl rke2 prereq [flags]uipathctl rke2 prereq [flags]
Options
--excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
      --included strings   components to be included in the execution, defaults to all
  -o, --output output      output format. one of [json,yaml,text] (default text)
      --upgrade            include upgrade-related checks      --excluded strings   components to be excluded from execution, defaults to none
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
