uipathctl reference guide
Last updated Apr 28, 2025
uipathctl internal rke2 hydrate-agent-dir
Copy the infra images to the agent directory on all nodes.
uipathctl internal rke2 hydrate-agent-dir [flags]uipathctl internal rke2 hydrate-agent-dir [flags]
Options
--concurrency int           Number of agent nodes copy images concurrently (default 3)
  -h, --help                      help for hydrate-agent-dir
      --images-filepath string    ImageList filePath
      --is-insecure               Is registry hosted over insecure/http server
      --name string               System upgrade controller plan name
      --password string           Password for source registry
      --src-registry-url string   Source registry URL for copying images
      --tmp-path string           Path to copy uipathcore and Imagelist (default "/tmp")
      --username string           Username for source registry
      --versions string           Artifacts file server URL (default "upgrade-server-service.kube-system.svc.cluster.local:80")      --concurrency int           Number of agent nodes copy images concurrently (default 3)
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
