- Overview
- Pre-installation
- Cluster administration- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management- uipathctl config additional-ca-certificates
- Upgrade
- Authentication- uipathctl config argocd generate-dex-config
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- Product-specific configuration- uipathctl config orchestrator
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Apr 28, 2025
               The command executes the migration from a source directory to a target cluster.
            uipathctl cluster migration import [flags]uipathctl cluster migration import [flags]# Import the cluster state from local directory to cluster
        uipathctl cluster migration import        # Import the cluster state from local directory to cluster
        uipathctl cluster migration import-h, --help              help for import
      --versions string   path to versions file  -h, --help              help for import
      --versions string   path to versions file--context string      name of the kubeconfig context to use
      --timeout duration    timeout of the command (default 5h0m0s)      --context string      name of the kubeconfig context to use
