uipathctl reference guide
Last updated Apr 28, 2025
uipathctl service aicenter sync-skills
Synchronise the AI Center skills.
uipathctl service aicenter sync-skills [flags]uipathctl service aicenter sync-skills [flags]
Options
-h, --help               help for sync-skills
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")  -h, --help               help for sync-skills
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
