uipathctl reference guide
Last updated Apr 28, 2025
uipathctl rke2 node remove
Gracefully remove the k8s nodes.
uipathctl rke2 node remove [flags]uipathctl rke2 node remove [flags]
Options
-h, --help                     help for remove
      --ignore-lock              [CAUTION] Ignore single instance lock check. Use this only when previous script run failed to remove lock
      --ignore-missing-tainted   Ignore if a replacement tainted node is not available in the cluster
      --ignore-missing-zone      Ignore if a replacement node is not available in the same zone as provided nodes
  -n, --name string              [Required] : Comma separated list of node names to remove from the cluster.-h, --help                     help for remove
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
