uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config token-signing-certificates automatic-key-management enable
Enable automatic key management for identity.
uipathctl config token-signing-certificates automatic-key-management enable [flags]uipathctl config token-signing-certificates automatic-key-management enable [flags]
Examples
# Enable automatic key management for identity when the UiPath Automation Suite is deployed in the custom namespace
uipathctl config token-signing-certificates automatic-key-management enable --namespace custom-namespace
# Enable automatic key management for identity when the UiPath Automation Suite is deployed in the uipath namespace
uipathctl config token-signing-certificates automatic-key-management enable# Enable automatic key management for identity when the UiPath Automation Suite is deployed in the custom namespace
Options
-h, --help               help for enable
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")  -h, --help               help for enable
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
