- Overview
- About uipathctl
 - uipathctl reference documentation
 - Pre-installation
 - Cluster administration
 - Backup and restore
- uipathctl snapshot
 - uipathctl snapshot backup
 - uipathctl snapshot delete
 - uipathctl snapshot list
 - uipathctl snapshot restore
 - Certificate management
 - Upgrade
 - Authentication
 - Monitoring and alerting
 - Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS.
         You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
For more information, including a complete list of
         uipathctl operations, see the uipathctl reference documentation.
         You can install
         uipathctl on the Linux, macOS, and Windows platforms.
         Note:
      Currently,
         uipathctl is only compatible with the x86 architecture.
               You cannot run uipathctl on machines based on the ARM architecture,
               such as Macs with Apple Silicon (M series) CPUs.
