- Overview
- About uipathctl
- uipathctl reference documentation
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
-h, --help help for uipathctl
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
