- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Get the current SAML certificate used in the cluster in
pem
format.
The command defaults to the current context in the
kubeconfig
file. If the --kubeconfig
flag is set, it uses the kubeconfig
file specified by the flag.
uipathctl identity get-saml-certificate [flags]
# Get the current saml certificate from the cluster
# Get the current saml certificate from the cluster with additional certificate information
uipathctl identity get-saml-certificate --show-details
# Get the current saml certificate from the cluster identified by the current context in the kubeconfig file
uipathctl identity get-saml-certificate --kubeconfig cluster.kubeconfig
-h, --help help for get-saml-certificate
--show-details if true, additional saml certificate information will be printed
