- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
Process Mining
Architecture overview
linkThis page provides an overview the architecture of Process Mining. Process Mining extracts data from source systems (for example, SAP, Salesforce, ServiceNow), transforms it into event logs, and displays it in interactive process dashboards.
Process Mining portal
linkProcess Mining engine
linkThe Process Mining engine is responsible for:
Data transformation: Moving the data from blob storage to the data warehouse, and transforming the data for use in the dashboards.
Dashboard interaction: Calculating the process graph, charts and KPIs shown in dashboards.
Extraction tools
linkUsers have the option to either directly upload data files in the portal or utilize extraction tools to extract data from source systems and subsequently upload it to dedicated blob storage.
Platform services
linkPlatform Services are a set of central services in Automation Suite that provide functionalities such as identity, licensing, and tenant management.
