- Release notes
 - Before you begin
 - Getting started
 - Integrations
 - Working with process apps
- Working with dashboards and charts
 - Working with process graphs
 - Working with Discover process models and Import BPMN models
 - Showing or hiding the menu
 - Context information
 - Export
 - Filters
 - Sending automation ideas to UiPath® Automation Hub
 - Tags
 - Due dates
 - Compare
 - Conformance checking
 - Root cause analysis
 - Simulating automation potential
 - Viewing Process data
 - Creating apps
 - Loading data
 - Customizing process apps
 - App templates
 - Additional resources
- Out-of-the-box Tags and Due dates
 - Editing data transformations in a local environment
 - Designing an event log
 - Extending the SAP Ariba extraction tool
 - Performance characteristics
Process Mining
UiPath® Process Mining is a Process Mining solution that transforms data from your IT systems into visual interactive dashboards. This allows you to see existing value decreases, bottlenecks, and discrepancies, as well as understanding the root-causes and possible risks. It offers real-time, valuable insights to improve business processes over time.
UiPath® Process Mining enables all levels of an organization to understand business processes and identify new solutions to drive business performance improvement.
Data transformation
Visualize your data by extracting it to deliver real-time multidimensional process models. The data can be transformed and cleaned up, so it fits the expected input of the app. You can add business logic and enrich the data to enhance the possibilities for analysis.
Data analysis
Use process apps to do initial analysis and configure the app to make it ready for business roll-out. Incorporate business procedures and rules to develop detailed reference for every business transaction across teams.
Continuous monitoring
Deploy the app to business users for continuous monitoring of your process. Discover key business risks and enable opportunities for optimization and transformation.
