- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- Publishing Dashboards
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
DataBridgeAgent data extraction workflow for Process Mining on Automation Suite, covering source extraction and dataset preparation.
Similar to extracting data and preparing a dataset for use in a on-premises (stand-alone) Discovery Accelerator, you must extract data from the source system and create a dataset for use in Process Mining. This page describes how you can extract data from your source system for use in Process Mining using DataBridgeAgent.
DataBridgeAgent is used to extract data from the source system, and exports .tsv files. These .tsv files are loaded into the Microsoft SQL Server database using CData Sync. The following illustration shows an overview of the data flow.
Only use DataBridgeAgent if you have a custom .mvp connector. Otherwise, use CData Sync, Theobald Xtract Universal for SAP, or file to upload data.
