- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
Create a source connection
Process Mining
Last updated Jul 24, 2025
Note: Refer to the Configuring CData Sync section in the documentation of your app template for specific settings for setting up the source connection.
Note: Check the CData Sync documentation for any specific settings or requirements for your source system.
Follow these steps to set up the source connection.
Step |
Action |
1 | In the CData Sync Admin console, create a new Source connection for your source system.
Note: If your source system is not in the list you can disable the Only installed option to display all available source systems.
2 | Enter a descriptive name for the source connection in the Connection Name field. |
3 | Enter the required properties to set up a connection with your source system. |
4 | Create and Test the connection. |
If you want to set up a source connection to load data from
.csv
or .tsv
files make sure to:
- Select CSV as the source system to which you want to create a connection from the list.
- Set the URI to the path where the
.csv
or.tsv
files are stored. - Set the correct ConnectionType. Use Local when the files are stored on the same server as CData Sync.
- Set FMT to the appropriate value used in the data files.
Section | Parameter | Value |
Schema | Type Detection Scheme | None |
Data Formatting | Push Empty Values As Null | True |
Miscellaneous | Exclude File Extensions | True |
Miscellaneous | Include Files | Add ,TSV to the setting if you want to upload .tsv files
