- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Using .mvp Connectors
- Downloading DataBridgeAgent
- DataBridgeAgent
- System requirements
- Configuring DataBridgeAgent
- Adding a custom connector to DataBridgeAgent
- Using DataBridgeAgent with SAP Connector for Purchase-to-Pay Discovery Accelerator
- Using DataBridgeAgent with SAP Connector for Order-to-Cash Discovery Accelerator
- Extending the SAP Ariba extraction tool
- Performance characteristics
Process Mining
Last updated Jul 24, 2025
In Process Mining (Automation Suite), an existing Process Mining on-premises (standalone) connector (
.mvp
file) can be loaded using DataBridgeAgent. This enables you to reuse the existing Data transformations, and load the output data into a process app in Process Mining Automation Suite.
See Adding a custom connector to DataBridgeAgent for a detailed description on how to add a
.mvp
connector file created in Process Mining on-premises (standalone) to DataBridgeAgent.
