Process Mining user guide
Loading data using DataBridgeAgent
DataBridgeAgent usage scope and prerequisites for loading on-premises data into Process Mining on Automation Suite.
Note:
DataBridgeAgent is only needed if you are migrating from an on-premises stand-alone Process Mining version. Only use DataBridgeAgent if you have a custom .mvp connector. Otherwise, use CData Sync, Theobald Xtract Universal for SAP, or files to upload data.
Important:
Using a proxy server is not supported for loading data using DataBridgeAgent.
Important:
Always make sure that the data is in the required input format for the app template. See App Templates. This can be done either in the Data transformations, or by renaming the output fields of the on-premises stand-alone connector (.mvp).
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
