- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
Process Mining
Last updated Jul 24, 2025
2023.10.4
There was an issue where editing Data transformations did not work when the process app security was configured as
single_account
. This issue has now been resolved.
Check out Configuring process app security in the Automation Suite guide for more information.
If you use Amazon S3 storage objects and you want to prevent uploading data using a pre-signed URL, this is now handled via
the global
disable_presigned_url
flag.
Refer to Pre-signed URL configuration in the Automation Suite guide for more information.
We now support CData Sync 2024 - 24.1.8885 for Loading data using CData Sync.
We are constantly working to improve your UiPath® Process Mining experience. Even though there are no major significant changes with this release, we made sure to bring security and accessibility improvements as well as minor bug fixes to our product.
