- Release notes
 - Before you begin
 - Getting started
 - Integrations
 - Working with process apps
- Working with dashboards and charts
 - Working with process graphs
 - Working with Discover process models and Import BPMN models
 - Showing or hiding the menu
 - Context information
 - Export
 - Filters
 - Sending automation ideas to UiPath® Automation Hub
 - Tags
 - Due dates
 - Compare
 - Conformance checking
 - Root cause analysis
 - Simulating automation potential
 - Viewing Process data
 - Creating apps
 - Loading data
 - Customizing process apps
 - App templates
 - Additional resources
- Out-of-the-box Tags and Due dates
 - Editing data transformations in a local environment
 - Designing an event log
 - Extending the SAP Ariba extraction tool
 - Performance characteristics
Process Mining
Last updated Sep 24, 2025
PostgreSQL for Process Mining Airflow databases
For Process Mining on Automation Suite 2023.10.9 or higher, you can now choose to use PostgreSQL for the
                  AutomationSuite_Airflow database. If you choose not to use PostgreSQL and keep using Microsoft SQLServer, Process Mining on Automation Suite will
                     run with a legacy version of Airflow.
                  Refer to SQL Requirements for Process Mining for more information on how to set up a PostgreSQL
                  AutomationSuite_Airflow metadatabase.
                  Important:
               You are recommended to move to PostgreSQL for the Airflow database, as PostgreSQL runs with the latest versions of Apache Airflow. Latest versions of Apache Airflow have various functionality, performance, and security fixes that older versions lack.
Upcoming removal
In Process Mining on Automation Suite 2025.10, we will no longer support Apache Airflow versions older than Airflow 2.9.0.
                     This implies that, starting with Process Mining on Automation Suite 2025.10, you can no longer use Microsoft SQL Server for
                     the
                  AutomationSuite_Airflow database. Newer Airflow versions do not support Microsoft SQL Server for Airflow meta databases.
                  For the
                  AutomationSuite_Airflow database, a PostgreSQL database is required for Process Mining on Automation Suite 2025.10. This will apply to both new installations
                     and existing installations that upgrade to 2025.10.
                  You can already start using PostgreSQL for the
                  AutomationSuite_Airflow database in Process Mining on Automation Suite 2023.10.9.
                  Also check out the Deprecation timeline in the Overview guide.
We are constantly striving to improve your UiPath® Process Mining experience. While this release brings no major changes, we included security and accessibility improvements, as well as minor bug fixes.
