- Overview
 - Requirements
- Q&A: Deployment templates
 - Configuring the machines
 - Configuring the external objectstore
 - Configuring an external Docker registry
 - Configuring the load balancer
 - Configuring the DNS
 - Configuring Microsoft SQL Server
 - Configuring the certificates
 - Online multi-node HA-ready production installation
 - Offline multi-node HA-ready production installation
 - Disaster recovery - Installing the secondary cluster
 - Enabling Redis High Availability Add-On for the cluster
 - Document Understanding configuration file
 - Cluster administration
 - Monitoring and alerting
 - Migration and upgrade
- Migration options
 - Troubleshooting
 - How to clear Redis data
 - How to enable Istio logging
 - GPU node affected by resource unavailability
 - Failure to resize PVC
 - Failure to resize objectstore PVC
 - Storage reclamation patch
 - ArgoCD login failed
 - Redis probe failure
 - RKE2 server fails to start
 - Issues accessing the ArgoCD read-only account
 - Pods stuck in Init:0/X
 - Failure to configure email alerts post upgrade
 - No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
 - Failed status when creating a data labeling session
 - Failed status when trying to deploy an ML skill
 - Migration job fails in ArgoCD
 - Handwriting recognition with intelligent form extractor not working
 - Failed ML skill deployment due to token expiry
 - Exploring Logs
This page outlines the capabilities and product offerings you can enjoy if you install Automation Suite, and helps you get an idea about the architecture you are about to build.
Automation Suite enables you to deploy the full UiPath® automation platform in a Linux environment ranging from bare metal machines to on-premises Virtual Machine infrastructure, or cloud subscriptions to any of the major providers.
Managing multiple server product deployments independently usually requires configuring integrations with enterprise systems for authenticating and managing users, as well as managing and monitoring each deployment from an availability and scale perspective.
Automation Suite contains everything in one package that you can deploy in multi-node HA-ready production mode with automatic scaling and built-in HA, and monitor, configure, and upgrade as a whole. All the functionality available in Automation Cloud is adapted to make it easier for you to manage everything yourself with low total cost of ownership.
What Automation Suite includes:
- All Server Products (except for any new products shipping in Automation Cloud first).
 - All Shared Suite Capabilities that enable you to easily configure the integration with existing enterprise systems, such as AD, AAD, or SAML, across all products. A common experience is offered across the suite for the user, tenant, external applications, and license management.
 - Common end user portal.
 - Kubernetes-based infrastructure, cluster management, and monitoring tools, all preconfigured, dedicated to and optimized for UiPath®. This enables running all the products at scale and with HA. This means you do not have to design, configure, and validate which Kubernetes versions and components for routing, storage, etc., work well with the UiPath® services.
Everything needed is included and optimized, all supported by UiPath®.
You just need to bring the machines, load balancer, and SQL. For the specific requirements for the machines as well as installation options and instructions, see and the remaining of this section.
For a leaner stack, reduced complexity, and more streamlined operations, Automation Suite is available for containerized platforms such as AKS, a managed Kubernetes service offered by Azure, or EKS provided by Amazon AWS. For more details, refer to Automation Suite on EKS/AKS Installation Guide.
For an in-depth perspective on each deployment model, see .
Deployment Scenarios
- Online single-node evaluation
 - Offline single-node evaluation
High Availability
cluster_config.json configuration at installation time. We also support the ability to add more nodes to either single-node evaluation or multi-node
                     HA-ready production configurations to scale out. However, we do not support going from non-HA to HA mode.
                  Upgrade
The upgrade process covers both the infrastructure and the entire UiPath® automation platform.
Cluster management
We are using Rancher as the UI layer for managing our cluster. The UI provides a cluster explorer to manage the deployment.
Monitoring
The platform exposes Grafana, Prometheus, and Alertmanager by default for troubleshooting and monitoring. See how to monitor the cluster, set alerts, create and view dashboards to track the deployment here.
For more details, see .
Support Bundle
Support Bundle tool collects logs from the in-cluster object/blob store, logs from currently running pods (of last four hours), different events, and Kubernetes object definitions.
For more details on how to use the tool, see Support Bundle.
Backup and restore
The suite supports backup and recovery for the entire cluster except for external data sources, such as SQL Server.
Cluster backup is enabled by default every 15 minutes.
For more details, see Backing up and restoring the cluster.
SQL authentication methods
The suite supports both SQL authentication and Kerberos authentication for all SQL database connections.
Learn more about Automation Suite products.
Requirements and installation
                                  Details  |
                                  Instructions  |
                                  Requirements and installation instructions for Automation Suite.  |
Platform evaluation
                                  Details  |
                                  Instructions  |
                                  Complete an initial platform configuration.  | |
                                  Connect your first robot  | |
                                  Monitor the stack, troubleshoot issues, create alerts, and view dashboards from a centralized location.  |
Product evaluation
The following instructions take you to the corresponding product guides.
                                  Product  |
                                  Evaluation checklist  |
                                  Orchestrator  | |
                                  Automation Suite Robots  | |
                                  Automation Hub  | |
                                  Automation Ops  | |
                                  Test Manager  | |
                                  AI Center  | |
                                  Action Center  | |
                                  Task Mining  | |
                                  Apps  | |
                                  Insights  | |
                                  Data Service  | |
                                  Process Mining  | |
                                  Document Understanding  |
