Last updated Jul 14, 2025
Using the monitoring stack
The monitoring stack for Automation Suite clusters includes Prometheus, Grafana, and Alertmanager, which are integrated within the Rancher Cluster Explorer UI.
Note:
Node failures might lead to a Kubernetes shutdown, which would disrupt Prometheus alerts. To prevent this, we recommend setting up a separate alert on the RKE2 server.
This page describes a series of monitoring scenarios. For more details, see the official Rancher documentation on using Rancher Monitoring.
Important:
When using collectors to export metrics to third-party tools, enabling application monitoring may disrupt the functionality of Automation Suite.
Accessing the monitoring tools
The monitoring stack for Automation Suite clusters includes Prometheus, Grafana, Alert Manager, and Longhorn Dashboard.
You can access the Automation Suite monitoring tools individually using the following URLs:
Application
Tool
URL
Example
Metrics
Prometheus
https://monitoring.fqdn/metrics
https://monitoring.automationsuite.mycompany.com/metrics
Dashboard
Grafana
https://monitoring.fqdn/dashboard
https://monitoring.automationsuite.mycompany.com/dashboard
Alert Management
Alert Manager
https://monitoring.fqdn/alertmanager
https://monitoring.automationsuite.mycompany.com/alertmanager
Persistent Block Storage
Longhorn dashboard
https://monitoring.automationsutie.mycompany.com
Monitoring tool authentication
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
  • Username: admin
  • Password: to retrieve the password , run the following command:
    kubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -dkubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -d
docs image
Dex authentication
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
Note:
Dex is a basic authentication method that is layered over the monitoring tools. Therefore, updating the Dex password does not impact the passwords for the monitoring tools. In this scenario, the passwords for the monitoring tools remain the same as before.
  1. Run the following command by replacing newpassword with your new password:
    password="newpassword"
    password=$(echo -n $password | base64)
    kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword"
  2. Run the following command by replacing <cluster_config.json> with the path to your configuration file:
    /opt/UiPathAutomationSuite/UiPath_Installer/install-uipath.sh -i <cluster_config.json> -f -o output.json --accept-license-agreement/opt/UiPathAutomationSuite/UiPath_Installer/install-uipath.sh -i <cluster_config.json> -f -o output.json --accept-license-agreement
Checking currently firing alerts
To view the alerts, navigate to Prometheus using https://monitoring.fqdn/metrics and select the Alerts tab. Here you can see all the alerts configured in Automation Suite.
To view the active alerts, filter the alert status by selecting the Firing checkbox and the Show annotations checkbox at the top. Here you can see all the alerts that are firing currently and their corresponding messages.
Silencing alerts
If alerts are too noisy, you can silence them. To do that, take the following steps:
  1. Select the Alertmanager tile in the upper left corner of the Monitoring dashboard. The following screen is displayed.
  2. Find the alert in question, and select Silence.
  3. Fill in the Creator and Comment details, and select Create. The alert should no longer show on the Monitoring Dashboard or be reported to any of the configured receivers.
Configuring the alerts
Note:
You can find uipathctl in the Automation Suite installation folder: .../UiPathAutomationSuite/UiPath_Installer/bin.
Before starting configuring the alerts, make sure to enable kubectl.
Adding a new email configuration
To add a new email configuration after an installation, run the following command:
./uipathctl config alerts add-email \
  --name test \
  --to "[email protected]" \
  --from "[email protected]" \
  --smtp server.mycompany.com \
  --username admin \
  --password somesecret \
  --require-tls \
  --ca-file <path_to_ca_file> \
  --cert-file <path_to_cert_file> \
  --key-file <path_to_key_file> \
  --send-resolved./uipathctl config alerts add-email \
  --name test \
  --username admin \
  --require-tls \
  --send-resolved
Flag
Example
name
The name of the email configuration
testconfig
to
The email address of the receiver
from
The email address of the sender
SMTP
SMTP server URL or IP address and port number
server.mycompany.com:567
username
Authentication username
admin
password
Authentication password
securepassword
require-tls
Boolean flag to denote that TLS is enabled at the SMTP server.
N/A
ca-file
File path containing the CA Certificate of the SMTP server. This is optional if the CA is private.
./ca-file.crt
cert-file
File path containing the certificate of the SMTP server. This is optional if the certificate is private.
./cert-file.crt
key-file
File path containing the private key of the certificate of the SMTP server. This is required if the certificate is private.
./key-file.crt
send-resolved
Boolean flag to send an email once the alert is resolved.
N/A
Removing an email configuration
To remove an email configuration, you must run the following command. Make sure to pass the name of the email configuration you want to remove.
./uipathctl config alerts remove-email --name test./uipathctl config alerts remove-email --name test
Updating an email configuration
To update an email configuration, you must run the following command. Make sure to pass the name of the email configuration you want to update and the additional optional parameters you want to edit. These parameters are the same as the ones for adding a new email configuration. You can pass one or more flags at the same time.
./uipathctl config alerts update-email --name test [additional_flags]./uipathctl config alerts update-email --name test [additional_flags]
Accessing Grafana dashboard
To access Grafana dashboards, you must retrieve your credentials and use them to log in:
  • Username:
    kubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-user}" | base64 -d; echokubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-user}" | base64 -d; echo
  • Password:
    kubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-password}" | base64 -d; echokubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-password}" | base64 -d; echo
Monitoring the Service Mesh
You can monitor the Istio Service Mesh via the following Grafana dashboards: Istio Mesh and Istio Workload.
Istio Mesh dashboard
This dashboard shows the overall request volume, as well as 400 and 500 error rates across the entire service mesh, for the selected time period. The data is displayed in the upper-right corner of the window. See the 4 charts across the top for this information.
It also shows the immediate Success Rate over the past minute for each individual service. Note that a Success Rate of NaN indicates the service is not currently serving traffic.
Istio Workload dashboard
This dashboard shows the traffic metrics over the time range selected in the upper-right corner of the window.
Use the selectors at the top of the dashboard to drill into specific workloads. Of particular interest is the uipath namespace.
The top section shows overall metrics, the Inbound Workloads section separates out traffic based on origin, and the Outbound Services section separates out traffic based on destination.
Monitoring Persistent Volumes
You can monitor persistent volumes via the Kubernetes / Persistent Volumes dashboard. You can keep track of the free and used space for each volume.
You can also check the status of each volume by selecting the PersistentVolumes item within the Storage menu of the Cluster Explorer.
Monitoring hardware utilization
To check the hardware utilization per node, you can use the Nodes dashboard. Data on the CPU, Memory, Disk, and Network is available.
You can monitor the hardware utilization for specific workloads using the Kubernetes / Compute Resources / Namespace (Workloads) dashboard. Select the uipath namespace to get the needed data.
Creating shareable visual snapshot of a Grafana chart
  1. Select the downwards pointing arrow next to the chart title, and then select Share.
  2. Select the Snapshot tab, and set the Snapshot name,Expire, and Timeout.
  3. Select Publish to snapshot.raintank.io.
For more details, see the Grafana documentation on sharing dashboards.
Note: This snapshot is viewable on the public Internet by anyone with the link.
Creating custom persistent Grafana dashboards
For details on how to create custom persisten Grafana dashboards, see Rancher documentation.
Admin access to Grafana
Admin access to Grafana is not typically needed in Automation Suite clusters as dashboards are available for read access by default to anonymous users, and creating custom persistent dashboards must be created using the Kubernetes-native instructions previously linked in this document.
Nonetheless, admin access to Grafana is possible with the following instructions.
The default username and password for Grafana admin access can be retrieved as follows:
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-user}' | base64 -d && echo
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-password}' | base64 -d && echokubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-user}' | base64 -d && echo
Note that in High Availability Automation Suite clusters, there are multiple Grafana pods in order to enable uninterrupted read access in case of node failure, as well as a higher volume of read queries. This is incompatible with admin access because the pods do not share session state and logging in requires it. In order to work around this, the number of Grafana replicas must be temporarily scaled to 1 while admin access is desired. See the instructions on how to scale the number of Grafana replicas:
# scale down
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=1
# scale up
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=2# scale down
# scale up
Querying Prometheus
Creating custom alerts
You can create custom alerts using a Prometheus query with a Boolean expression.
  1. To do so, select Prometheus Rules in the Advanced menu of the Monitoring Dashboard.
  2. Select Create in the upper-right corner of the window to create a new alert, and follow the Rancher documentation: PrometheusRules
  3. When the alert fires, it should show on the Monitoring Dashboard. Additionally, it will be routed to any of the configured receivers.
Monitoring Kubernetes resource status
To see the status of pods, deployments, statefulsets, etc., you can use the Cluster Explorer UI. This is the same landing page as accessed after logging into the rancher-server endpoint. The homepage shows a summary, with drill downs into specific details for each resource type on the left. Note the namespace selector at the top of the page. This dashboard may also be replaced with the Lens tool.
Exporting Prometheus metrics to an external system
Prometheus uses the Prometheus remote write feature to collect and export Prometheus metrics to an external system.
Note: UiPath® does not support or maintain the remote write endpoint integrations. However, the endpoints are compatible with the Prometheus instance delivered within Automation Suite.
To configure remote_write on an Automation Suite cluster:
  1. Connect to ArgoCD.
  2. Select Applications.
  3. Navigate to fabric-installer.
  4. Open the APP DETAILS panel and disable self-heal.
  5. Navigate to the rancher-monitoring application.
  6. Open the APP DETAILS panel > MANIFEST tab.
  7. Select EDIT and navigate to the values > prometheus > prometheusSpec section.
  8. Add the desired remoteWrite configurations.
  9. SAVE the new configuration. The rancher-monitoring application displays OutOfSync until the new configuration is applied.
    Note: Prometheus does not need to restart to apply the new remote write configurations.
  10. Test the desired remote write integration. Return to step 8 to add a new configuration.
