Last updated Oct 15, 2025
AI Center provisioning failure after upgrading to 2023.10 or later
When upgrading from 2023.4.3 to 2023.10 or later, you might run into issues when provisioning AI Center.
The system shows the following exception, and the tenant creation fails: "exception":"sun.security.pkcs11.wrapper.PKCS11Exception: CKR_KEY_SIZE_RANGE
Solution
To resolve this issue, you must perform a rollout restart of the ai-trainer deployment by running the following command:
kubectl -n <uipath> rollout restart deploy ai-trainer-deploymentkubectl -n <uipath> rollout restart deploy ai-trainer-deployment
  • Description
  • Solution
