Last updated Oct 13, 2025
AI Center provisioning failure after upgrading to 2023.10 or later
When upgrading from 2023.4.3 to 2023.10 or later, you might run into issues when provisioning AI Center.
The system shows the following exception, and the tenant creation fails: "exception":"sun.security.pkcs11.wrapper.PKCS11Exception: CKR_KEY_SIZE_RANGE
Solution
To resolve this issue, you must perform a rollout restart of the ai-trainer deployment by running the following command:
kubectl -n uipath rollout restart deploy ai-trainer-deploymentkubectl -n uipath rollout restart deploy ai-trainer-deployment
  • Description
  • Solution
