Last updated Oct 13, 2025
Configuring credential stores
The following secure stores are already available in Orchestrator:
  • Azure Key Vault
  • CyberArk CCP
  • HashiCorp Vault
  • Thycotic Secret Server
  • Beyond Trust
  • AWS Secrets Manager
Any credential store plugin you choose to use must be Linux-compatible.
To disable the default plugins, set the Plugins.SecureStores.Default key as an empty string in the appsettings.json file. See Configuring appSettings for details.
