- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
You can enable and disable products in Automation Suite at any point post-installation.
input.json
file and apply the new
configuration via uipathctl.
Enabling or disabling Action Center
input.json
file:
"actioncenter": {
"enabled": "true" //Set to "false" to disable the Action Center
"actioncenter": {
Enabling or disabling Apps
enable
flag and an SQL database.
sql_connection_string_template_odbc
in
input.json
, then the default database name
is AutomationSuite_Apps
sql_connection_str
inside the Apps field. This overrides the default database and connection string template set in sql_connection_string_template_odbc
input.json
file:
"apps": {
"enabled": "true" //Set to "false" to disable the Apps
"sql_connection_str": "" ////Optional and only require to override the default database name
"apps": {
Enabling or disabling AI Center
enable
sql_connection_string_template_jdbc
in
input.json
, then the default AI Center
database name is AutomationSuite_AICenter
sql_connection_str
inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc
input.json
:"aicenter": {
"enabled": "true", //Set to "false" to disable the AICenter
"sql_connection_str": "" //Optional and only required to override the default database name
"aicenter": {
AI Center installed in Automation Suite on AKS/EKS cannot connect to an external Orchestrator.
Enabling or disabling Automation Hub
automation_hub
section of the input.json
file, set the enabled
flag
to true
"automation_hub": {
"enabled": "true" //Set to "false" to disable Automation Hub
"sql_connection_str": "" //Optional and only require to override the default database name
"automation_hub": {
enabled
flag to false
in the
automation_hub
file.
Enabling or disabling Automation Ops
enable
in input.json
, then the default database name for
Automation Ops is AutomationSuite_Platform
sql_connection_str
inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template
input.json
"automation_ops": {
"enabled": "true", //Set to "false" to disable the Automation Ops
"automation_ops": {
Enabling or disabling Automation Suite Robots
Before enabling Automation Suite Robots, make sure you meet the requirements.
To enable Automation Suite Robots, take the following steps:
Enable the
asrobots
flag in the
file. If you want to enable package caching, make sure to properly configure theinput.json
packagecaching
andpackagecachefolder
flags as well.{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }
{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }Parameter
Default value
packagecaching
When set totrue
, robots use a local cache for package resolution.packagecachefolder
/uipath_asrobots_package_cache
The disk location on the serverless agent node where the packages are stored.
Note: Package caching optimizes your process runs and allows them to run faster. NuGet packages are fetched from the filesystem instead of being downloaded from the Internet/network. This requires an additional space of minimum 10GB and should be allocated to a folder on the host machine filesystem of the dedicated nodes. -
If you use a multi-node HA-ready production setup, you must configure a specialized agent node for Automation Suite Robots.
asrobots
flag in the input.json
file.
Enabling or disabling Data Service
enable
in input.json
, then the default database name is
AutomationSuite_DataService
sql_connection_str
inside the Data Service field. This overrides the default database and connection string template set in sql_connection_string_template
input.json
"dataservice": {
"enabled": "true", //Set to "false" to disable the Data Service,
"dataservice": {
Enabling or disabling Document Understanding
enable
in
input.json
is AutomationSuite_DU_Datamanager
sql_connection_str
inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc
input.json
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "***" // dotnet connection string,
"datamanager": {
"sql_connection_str": "***" // odbc connection string
"pyodbc_sql_connection_str": "***" // python sql connection string
"enabled": true,
"datamanager": {
Enabling or disabling Insights
enable
in input.json
AutomationSuite_Insights
sql_connection_str
inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template
enable_realtime_monitoring
flag to true
Insights has an optional SMTP configuration to enable receiving email notifications. For details, see Configuring input.json.
input.json
"insights": {
"enabled": "true", //Set to "false" to disable the Insights,
"enable_realtime_monitoring": "false", //Set to "true" to enable Insights Real-time monitoring,
"insights": {
Enabling or disabling Orchestrator
orchestrator
flag to true
in
the input.json
file.
"orchestrator": {
"enabled": "true" //Set to "false" to disable Orchestrator
"orchestrator": {
orchestrator
flag to false
in
the input.json
file.
Enabling or disabling Process Mining
input.json
file:
- Enable the
processmining
flag. -
Configure the following connection string templates:
sql_connection_string_template_sqlalchemy_pyodbc
Add a separate connection string for the second SQL Server:
"processmining": { "enabled": true, "sql_connection_str": "", // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }
processmining
flag.
Enabling or disabling Task Mining
enable
flag and an SQL Database.
in input.json
AutomationSuite_Task_Mining
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads.
input.json
"task_mining": {
"enabled": "true", //Set to "false" to disable the Task Mining,
"task_mining": {
Un-tainting for workloads
If desired, the Task Mining node can be repurposed as an agent node. To accomplish this, run the following commands:
- Check an actual taint using
kubectl describe node task-mining_nodename
command. - Run the command
kubectl taint nodes task-mining_nodename task.mining/cpu=present:NoSchedule-
. - Check taint has disappeared using
command.
Enabling or disabling Test Manager
enable
in input.json
AutomationSuite_Test_Manager
sql_connection_str
inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template
input.json
"test_manager": {
"enabled": "true", //Set to "false" to disable the Test Manager,
"test_manager": {
input.json
, run the following commands with the uipathctl
installer to update the service configuration:
- Run the following command to get an output of what changes will be made to the cluster:
# uipathctl manifest apply --dry-run input.json --versions versions.json automationhub deleted (dry-run) platform updated (dry-run)
# uipathctl manifest apply --dry-run input.json --versions versions.json automationhub deleted (dry-run) platform updated (dry-run) - To apply the changes on the cluster,
run:
# uipathctl manifest apply input.json --versions versions.json --log-level info --skip-helm
- Step 1: Changing the product selection in the configuration file
- Enabling or disabling Action Center
- Enabling or disabling Apps
- Enabling or disabling AI Center
- Enabling or disabling Automation Hub
- Enabling or disabling Automation Ops
- Enabling or disabling Automation Suite Robots
- Enabling or disabling Data Service
- Enabling or disabling Document Understanding
- Enabling or disabling Insights
- Enabling or disabling Orchestrator
- Enabling or disabling Process Mining
- Enabling or disabling Task Mining
- Enabling or disabling Test Manager
- Step 2: Running the installer to update the new product configuration
