Last updated Oct 13, 2025
Insights volumes created in two different zones following migration
When you migrate from Automation Suite on Linux to Automation Suite on EKS/AKS and your target cluster spans multiple zones, Insights-related volumes are occasionally created in two different zones. As a result, you may encounter issues when bringing up the Insights service.
Solution
To address the problem, take the following steps:
  1. Before migration, cordon the nodes in all zones, with the exception of the zone where you want the volumes to be located. To cordon the nodes, run the following command:
    kubectl cordon <node name>kubectl cordon <node name>
  2. Execute the Automation Suite on Linux to Automation Suite on EKS/AKS migration by running the command in Step 1 of Execution.
  3. Uncordon all the nodes you cordoned before the migration by running the following command:
    kubectl uncordon <node name>kubectl uncordon <node name>
  • Description
  • Solution
