Last updated Dec 4, 2025
EKS input.json example
The following example shows input.json with all products enabled, mandatory and optional configuration parameters for Automation Suite on EKS. You can use this as reference and make changes as per your environment requirements.
Note that the minimum UiPath® product selection requires platform to be enabled. Make sure to replace all the username and passwords, including SQL connection strings.
  "kubernetes_distribution": "eks",
  "install_type": "online",
  "profile": "ha",
  "registries": {
    "docker": {
      "url": "registry.uipath.com",
      "username": "",
      "password": ""
    "helm": {
      "username": "",
      "password": ""
  "fqdn": "automationsuite.mycompany.com",
  "admin_username": "admin",
  "admin_password": "password123",
  "fips_enabled_nodes": false,
  "fabric": {
    "redis": {
      "license": "", // fabric.redis.license must not be specified when fabric.redis.{hostname, password, port} are specified
      "ha":false,
      "hostname": "redis-cache.mycompany.com",
      "password": "redispassword",
      "port": 6380,
      "tls": true
  "pod_identity" : {
    "enabled": true,
    "aks_managed_identity_client_id": <client-id>
  "external_object_storage": {
    "enabled": true,
    "create_bucket": true,
    "storage_type": "azure",
    "use_managed_identity": false,
    "azure_fqdn_suffix": "core.windows.net",
    "account_key": "secretkey",
    "account_name": "as-storage-account",
    // storage type s3 specific config:
    "fqdn": null,
    "port": null,
    "region": "us-east-1",
    "access_key": "",
    "secret_key": "",
    "use_instance_profile": true,
    "bucket_name_prefix": "",
    "bucket_name_suffix": ""
  "ingress": {
    "service_annotations": {
      "service.beta.kubernetes.io/aws-load-balancer-backend-protocol": "ssl",
      "service.beta.kubernetes.io/aws-load-balancer-eip-allocations": "<elastic_ip_id_0>,<elastic_ip_id_1>",
      "service.beta.kubernetes.io/aws-load-balancer-nlb-target-type": "ip",
      "service.beta.kubernetes.io/aws-load-balancer-scheme": "internet-facing",
      "service.beta.kubernetes.io/aws-load-balancer-type": "nlb"
    "gateway_selector": {
      "istio": "ingressgateway"
  "istioMinProtocolVersion": "TLSV1_3",
  "disable_presigned_url": false,
  "tolerations": [],
  "exclude_components": [],
  "server_certificate": {
    "tls_cert_file": "",
    "tls_key_file": "",
    "ca_cert_file": ""
  "additional_ca_certs": "",
  "registry_ca_cert": "",
  "identity_certificate": {
    "saml_current_service_cert_file": "",
    "saml_current_service_cert_pass": "",
    "saml_future_service_cert_file": "",
    "saml_future_service_cert_pass": "",
    "ldap_cert_authority_file": ""
  "sql": {
    "create_db": false,
    "server_url": "",
    "port": "",
    "username": "",
    "password": ""
  "infra": {
      "bucket_name": "s3-sfd-ci-aseks3997852-common"
  "dataservice": {
      "bucket_name": "s3-sfd-ci-aseks3997852-dataservice"
    "enabled": true
  "platform": {
    "enabled": true
  "integrationservices": {
    "queue_prefix": "<queuePrefix>",
    "account_id":""
    "enabled": true,
  "studioweb": {
    "enabled": true,
  "orchestrator": {
    "enabled": true,
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
  "processmining": {
      "bucket_name": "s3-sfd-ci-aseks3997852-processmining"
    "enabled": true
  "insights": {
    "enabled": true,
    "enable_realtime_monitoring": false,
  "task_mining": {
      "bucket_name": "s3-sfd-ci-aseks3997852-taskmining"
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "aicenter": {
      "bucket_name": "s3-sfd-ci-aseks3997852-common",
      "port": 443,
      "fqdn": "s3.eu-west-1.amazonaws.com"
    "enabled": true
  "documentunderstanding": {
    "enabled": true
  "test_manager": {
    "enabled": true
  "action_center": {
    "enabled": true
  "apps": {
    "enabled": true
  "asrobots": {
    "packagecaching": true,
    "packagecachefolder": "/uipath_asrobots_package_cache",
    "enabled": true
  "storage_class": "ebs-sc",
  "storage_class_single_replica": "efs-sc",
  "proxy": {
    "enabled": true,
    "http_proxy": "<http://<PROXY-SERVER-IP>:<PROXY-PORT>",
    "https_proxy": "<http://<PROXY-SERVER-IP>:<PROXY-PORT>",
    "no_proxy": "paste list from Configuring the cluster section"
  "sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
  "sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com",
  "sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com",
  "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:[email protected]:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server",
  "postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:&lt;password&gt;@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
  "telemetry_optout": false
  "profile": "ha",
  "registries": {
    "docker": {
      "username": "",
      "password": ""
    "helm": {
      "username": "",
      "password": ""
  "fabric": {
    "redis": {
      "ha":false,
      "port": 6380,
      "tls": true
  "pod_identity" : {
    "enabled": true,
    "enabled": true,
    "fqdn": null,
    "port": null,
    "access_key": "",
    "secret_key": "",
  "ingress": {
  "tolerations": [],
    "tls_key_file": "",
    "ca_cert_file": ""
  "sql": {
    "create_db": false,
    "server_url": "",
    "port": "",
    "username": "",
    "password": ""
  "infra": {
  "dataservice": {
    "enabled": true
  "platform": {
    "enabled": true
    "account_id":""
    "enabled": true,
  "studioweb": {
    "enabled": true,
  "orchestrator": {
    "enabled": true,
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
  "processmining": {
    "enabled": true
  "insights": {
    "enabled": true,
  "task_mining": {
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "aicenter": {
      "port": 443,
    "enabled": true
    "enabled": true
  "test_manager": {
    "enabled": true
  "action_center": {
    "enabled": true
  "apps": {
    "enabled": true
  "asrobots": {
    "enabled": true
  "proxy": {
    "enabled": true,
